Razer Kraken V3 Pro
Razer Kraken V3 Pro
Quicklinx: HNL9WS00 Mfr#: RZ04-03460100-R3M1
Type: Headset
£166.66 ex VAT
£199.99 inc VAT
The construction of the Razer Kraken had a singular motivation - durability to withstand daily abuse on the go, whether they are tuning out your daily commute or providing the soundtrack while you hit the slopes. Their light-weight design makes these headphones comfortable for hours on end.
The ear cups of the Razer Kraken are foldable, making the footprint of these full-sized headphones extremely compact for maximum mobility so you can take them along anywhere you go.
The Razer Kraken is outfitted with large 40mm neodymium magnet drivers tuned for crystal clear music in the high-and mid-ranges and packing deep bass for powerful lows, making them versatile music and gaming headphones.
  • The deepest immersion, unleashed
    To reach the ultimate depths of immersion, one must dive beyond sight and sound. Unlock a third sense for gaming with the Razer Kraken V3 Pro - a wireless haptic PC gaming headset powered by Razer HyperSense. With the ability to feel what you hear, gaming has never felt this intense or real
  • Feedback that feels real - Razer HyperSense
    Cutting-edge haptic drivers in each earcup pick up on audio cues and convert them into realistic vibrations that vary in position, duration, and intensity, providing touch-sensory feedback for in-game sounds
  • Stereo haptics
    Haptic effects flow between left and right earcups based on in-game positioning for greater spatial awareness and immersion
  • Real-time haptics
    Intelligent audio processing that requires zero integration or additional downloads to work. Compatible across games, music, and movies
  • Intensity adjuster
    Easily adjust the haptics' strength with an on-headset button that can toggle between off, low, medium, and high
  • Immersion from every angle - thx spatial audio
    The headset is armed with advanced 7.1 surround sound that optimizes your game's sound design for realistic positional audio. Experience true-to-life acoustics and hear everything as if you were right in the middle of it all
  • Powerful, lifelike audio - Razer TriForce titanium 50mm drivers
    Our patented 3-part driver design pushes out exceptional highs, mids, and lows that doesn't muddy, providing a more dynamic listening experience for deeper immersion. Upgraded with titanium-coated diaphragms for superior clarity, the drivers enable truly lifelike and accurate sound reproduction
  • Sound that's seamless Razer hyper-speed wireless
    The haptic headset's industry-leading 2.4GHz wireless connection ensures lossless, low-latency audio that syncs perfectly with game visuals, so you'll never experience a break in immersion
  • Hybrid fabric and leatherette memory foam cushions
    The perfect balance of comfort, sound isolation, and haptics transfer.
  • Razer HyperClear super-cardioid mic
    The larger 9.9mm detachable mic suppresses more noise from the back and sides and provides a truer recreation of your voice thanks to a sensitive low frequency response
  • Works with PlayStation - wirelessly
    The Razer Kraken V3 Pro comes with a wireless dongle that's compatible with PlayStation so you can plug and play instantly, allowing you to enhance your overall console immersion through the combined haptics of your headset and controller
  • Powered by Razer Chroma RGB
    With 16.8 million colors and a suite of effects, enjoy greater immersion as it dynamically reacts with over 150 integrated games. Hold down the Razer HyperSense adjuster button to conveniently cycle through Razer Chroma RGB lighting effects
Razer Kraken V3 Pro - headset - 3.5 mm jack
Headset - 2.4 GHz - wireless, wired - 3.5 mm jack
Recommended Use
Game console, computer
Additional Functions
RGB lighting
Style
Games
Headphones Form Factor
Full size
Wireless, wired
Wireless Technology
2.4 GHz radio frequency
Sound Output Mode
Stereo
Sound Effects
THX Spatial Audio
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 96 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Uni-directional (HyperClear super cardioid)
Controls
Mute, volume, Haptics intensity
RGB lighting
Style
Games
368 g
Earpad Material
Leatherette, memory foam
Recommended Use
Audio Output
Full size
Wireless, wired
Wireless Technology
Sound Output Mode
Stereo
Sound Effects
THX Spatial Audio
Frequency Response
20 - 20000 Hz
Sensitivity
96 dB
Impedance
32 Ohm
Diaphragm
50 mm
Magnet Material
Razer Triforce titanium
Adjustable Headband
Razer HyperSense, Razer Chroma RGB
Microphone
Boom
Sensitivity
-42 dB
Sensitivity Margin
+/- 3dB
Frequency Response
100 - 10000 Hz
Signal-To-Noise Ratio
60 dB
Remote Control
Controls
Connector Type
Headset (mini-phone 3.5 mm 4-pole)
USB dongle
Cable Details
USB-C to USB-A cable - detachable , Mini-phone 3.5 mm 4-pole cable - detachable - 1.3 m
Headset battery rechargeable
Run Time (Up To)
44 hour(s)
Run Time Details
(lighting OFF / Haptics OFF): up to 44 hours , (lighting ON / Haptics ON): up to 11 hours
Type: Headset
Brand: Razer
