Dive into a new dimension of immersion with the Razer Kraken V3 HyperSense - a PC gaming headset powered by haptic technology. From rumbling explosions to whizzing bullets, with the ability to feel what you hear, the time has come to embrace true multi-sensory gaming.
Razer HyperSense
Cutting-edge haptic drivers in each earcup pick up on audio cues and convert them into realistic vibrations that vary in position, duration, and intensity, providing touch-sensory feedback for in-game sounds. -
Stereo haptics
Haptic effects flow between left and right earcups based on in-game positioning for greater spatial awareness and immersion. -
Real-time haptics
Intelligent audio processing that requires zero integration or additional downloads to work. Compatible across games, music, and movies. -
Intensity adjuster
Easily adjust the haptics' strength with an on-headset button that can toggle between off, low, medium, and high. -
THX spatial audio
The headset is armed with advanced 7.1 surround sound that optimizes your game's sound design for realistic positional audio. Experience true-to-life acoustics and hear everything as if you were right in the middle of it all. -
Razer TriForce titanium 50mm drivers
The patented 3-part driver design pushes out exceptional highs, mids, and lows that doesn't muddy, providing a more dynamic listening experience for deeper immersion. Upgraded with titanium-coated diaphragms for superior clarity, the drivers enable truly lifelike and accurate sound reproduction. -
Hybrid fabric and leatherette memory foam cushions
The perfect balance of comfort, sound isolation, and haptics transfer. -
Razer hyperclear cardioid mic
By suppressing sounds from the back and sides, the detachable mic offers greater speech pickup and noise cancellation, ensuring improved clarity and a natural representation of your voice. -
Powered by Razer Chroma RGB
With 16.8 million colors and a suite of effects, enjoy greater immersion as it dynamically reacts with over 150 integrated games. Hold down the Razer HyperSense adjuster button to conveniently cycle through Razer Chroma RGB lighting effects.
 - Razer Kraken V3 HyperSense - headset - USB-A
- Product Type
 - Headset - wired - USB-A
- Recommended Use
 - Computer, Game console
- Additional Functions
 - RGB lighting
- Style
 - Games
- Headphones Form Factor
 - Full size
- Connectivity Technology
 - Wired
- Sound Output Mode
 - Stereo
- Sound Effects
 - THX Spatial Audio
- Audio Specifications
 - Frequency Response 20 - 20000 Hz - Sensitivity 96 dB
- Impedance
 - 32 Ohm
- Noise Isolating
- Microphone
 - Boom
- Microphone Operation Mode
 - Uni-directional (super-cardioid)
- Controls
 - Volume, microphone on/mute
 - 2-year warranty
- Product Type
 - RGB lighting
- Style
 - Games
 - 27 cm
 - 15 cm
 - 28 cm
 - 344 g
- Earpad Material
 - Memory foam, leatherette
- Recommended Use
Audio Output
 - Full size
 - Wired
- Sound Output Mode
 - Stereo
- Sound Effects
 - THX Spatial Audio
- Noise Isolating
 - 20 - 20000 Hz
- Sensitivity
 - 96 dB
- Impedance
 - 32 Ohm
- Diaphragm
 - 50 mm
- Magnet Material
 - Razer Triforce titanium
 - Razer HyperSense, Razer Chroma RGB
Microphone
 - Boom
- Form Factor
 - Headset microphone
- Sensitivity
 - -42 dB
- Sensitivity Margin
 - +/- 3dB
 - 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
 - USB (4 PIN USB Type A)
Cable
- Cable Length
 - 2 m
- Cable Details
 - USB cable - 2 m
 - 2-year warranty
