Precise Quad Movement Button Layout for superior control and optimal execution;By replacing a joystick with 4 movement buttons, enjoy clean, crisp play without the input errors of typical fight sticks—from instantly buffering a charge to flawlessly performing complex motions
Razer Low-profile Linear Optical Switches for ultra-precise, ultra-responsive inputs;Featuring a shorter actuation height for greater response, the Razer Kitsune’s smooth, lightning-fast switches provide the speed and precision you need to maximize your footsies and whiff punishes
Slim, Portable Form Factor for easy storage and setup;The Razer Kitsune’s leverless design can be easily stored in your backpack, while its detachable USB Type C cable removes the need for constant coiling or uncoiling when packing or setting up
Cable Security Clasp and Tournament Lock Switch for uninterrupted tournament play; with a built-in lock to fasten the cable and a lock switch that disables non-essential buttons, secure your win in the heat of competition by eliminating accidental inputs and disconnections
Removable Aluminium Top Plate to fit your style;from stunning Razer Customs vinyl wraps to creating your own via our downloadable template, simply unscrew the top plate and apply your desired design
Powered by Razer Chroma RGB for extra fighting flair;With multiple color combinations and a suite of effects, customize the Razer Kitsune’s lighting to match your fighting style using a series of pre-loaded shortcuts
Enhanced durability
Crafted from high-quality aluminum, this arcade controller is built to withstand intense gaming sessions, ensuring long-lasting performance and reliability. -
Versatile compatibility
Designed to seamlessly integrate with both PC and Sony PlayStation 5, this controller offers gamers the flexibility to enjoy their favorite titles across multiple platforms. -
Advanced control
Featuring a precise quad movement button layout along with Razer Linear Low Profile Optical Switches, this controller delivers superior responsiveness and accuracy for an immersive gaming experience. -
Customizable aesthetics
With Razer Chroma lighting, gamers can personalize their controller's appearance, creating a unique gaming setup that stands out. -
Convenient features
The inclusion of a removable faceplate and a locking system provides an added layer of customization and security, while the 3.1 m cable ensures ample mobility during gameplay.
- Razer Kitsune - arcade controller - wired
- Product Type
- Arcade controller
- Connectivity Technology
- Wired
- Locking system, Razer Chroma lighting, Precise quad movement button layout, Razer Linear Low Profile Optical Switches, removable faceplate
- Black
- 1-year warranty
- Designed For
- PC, Sony PlayStation 5
- Product Type
- Arcade controller
- Wired
- Interface
- USB
- Black
- Material
- Aluminium
- OS Required
- Microsoft Windows
- Included Accessories
- USB-C to USB-A cable
- 29.6 cm
- 21 cm
- 1.92 cm
- 800 g
- Cable Length
- 3.1 m
- Limited warranty - 1 year
- Designed For
