Razer Kishi V2 USB-C
Quicklinx: HP8JWS00 Mfr#: RZ06-05110100-R3M1
Type: Gamepad
Hurry, only 1 left in stock!
£82.50 ex VAT
£99.00 inc VAT
Console-Quality Mobile Gaming Controls
The Razer Kishi V2 is designed to meet the standards of competitive console controllers with cutting edge microswitch buttons, analog triggers, and programmable macros.
Extendable Bridge for a Universal Fit with USB C
Compatible with most modern Android devices (Android 12 and up) and iPhone 15 - The Kishi V2’s USB C connection and extendable bridge perfectly secures smartphones in place while gaming.
Stream PC and Console Games
Use Kishi V2 to play full PC and console games directly on your phone, with support for the biggest game streaming apps - Stream from your own device or play from the cloud (Third party hardware and services may be required).
Optimized for Maximum Performance
By utilizing your smartphone’s TYPE C connection, Kishi V2 eliminates input latency, allowing for responsive, seamless control - and features passthrough charging so you can power your phone as you game.
Powered by the Razer Nexus App
Launch your games, customize your controls, record and share gameplay, and keep your Kishi V2 updated with the app that can be brought up at the touch of a dedicated button.
Virtual Controller Mode
Use Virtual Controller Mode to remap touch screen controls to the Kishi V2, adding controller compatibility to many of the biggest mobile games.
Requires - Android 12 or higher | iOS 17
  • Mobile gaming reimagined
    Rethink everything you knew about mobile gaming. Razer Kishi V2 is a universal mobile gaming controller that brings a console-class gameplay experience to your smartphone. Play the best AAA games, on your mobile phone, exactly as you'd expect to play them on a game console - zero compromises.
  • Console-quality mobile gaming controls
    The Razer Kishi V2 is designed to meet the standards of competitive console controllers with cutting edge micro switch buttons, analog triggers, and programmable macros.
  • Universal fit with extendable bridge
    The Razer Kishi V2 features a stable, extendable bridge that perfectly holds your iPhone, providing a secure fit that won't come loose while you game.
  • Ultra-low latency gameplay and passthrough charging
    By utilizing Lightning connection, Kishi V2 eliminates input latency, allowing for responsive, seamless control - and features passthrough charging so you can power your phone as you game.
  • Comfortable grip in a portable form-factor
    Designed for long gaming sessions, yet slim enough to fit into a pocket, the Razer Kishi V2 is optimized for both comfort and portability, with each button in just the right place.
Razer Kishi V2 - gamepad - wired
Gamepad
Wired
Adjustable width, pass through charging
1-year warranty
Android, iOS, PC
Gamepad
Wired
Android 12 or later, Apple iOS 17
26.56 cm
9.22 cm
3.39 cm
123 g
Limited warranty - 1 year
Android, iOS, PC
Type: Gamepad
Brand: Razer
