Rethink everything you knew about mobile gaming. Razer Kishi V2 is a universal mobile gaming controller that brings a console-class gameplay experience to your smartphone. Play the best AAA games, on your mobile phone, exactly as you'd expect to play them on a game console - zero compromises.
The Razer Kishi V2 is designed to meet the standards of competitive console controllers with cutting edge micro switch buttons, analog triggers, and programmable macros.
CONSOLE-QUALITY MOBILE GAMING CONTROLS
Microswitch Buttons, Analog Triggers, and Programmable Macros
The Razer Kishi V2 is designed to meet the standards of competitive console controllers with cutting-edge microswitch buttons, analog triggers, and programmable macros.
UNIVERSAL FIT WITH EXTENDABLE BRIDGE
Seamless Compatibility
The Razer Kishi V2 features a stable, extendable bridge that perfectly holds all modern iPhone models, providing a secure fit that won’t come loose while you game.
STREAM PC AND CONSOLE GAMES
Go Beyond Mobile Gaming
Use the controller to play full PC and console games directly on your iPhone, with support for the biggest game streaming apps. Stream from your own device, or play from the cloud.
OPTIMIZED FOR MAXIMUM PERFORMANCE
Ultra-low Latency Gameplay and Passthrough Charging
By utilizing your iPhone’s Lightning connection, the Razer Kishi V2 eliminates input latency, allowing for responsive, seamless control—and features passthrough charging so you can power your phone as you game.
ERGONOMIC DESIGN
Comfortable Grip In a Portable Form Factor
Designed for long gaming sessions, yet slim enough to fit into a pocket, the Razer Kishi V2 is optimized for both comfort and portability, with each button in just the right place
POWERED BY THE RAZER NEXUS APP
Maximum Versatility and Customizability
Browse through over a thousand compatible games, record and share gameplay, and keep the Razer Kishi V2 updated with an integrated app that allows full customizability—all with the touch of a dedicated button
SUPPORTED PHONE DIMENSIONS
- iPhone SE (1st and 2nd)
- iPhone 6S/6S Plus
- iPhone 7 and 7 Plus
- iPhone X, 8 and 8 Plus
- iPhone XS, XS Max, XR
- iPhone 11 series
- iPhone 12 series
- iPhone 13 series
Mobile gaming reimagined
Rethink everything you knew about mobile gaming. Razer Kishi V2 is a universal mobile gaming controller that brings a console-class gameplay experience to your smartphone. Play the best AAA games, on your mobile phone, exactly as you'd expect to play them on a game console - zero compromises. -
Console-quality mobile gaming controls
The Razer Kishi V2 is designed to meet the standards of competitive console controllers with cutting edge micro switch buttons, analog triggers, and programmable macros. -
Universal fit with extendable bridge
The Razer Kishi V2 features a stable, extendable bridge that perfectly holds your iPhone, providing a secure fit that won't come loose while you game. -
Ultra-low latency gameplay and passthrough charging
By utilizing Lightning connection, Kishi V2 eliminates input latency, allowing for responsive, seamless control - and features passthrough charging so you can power your phone as you game. -
Comfortable grip in a portable form-factor
Designed for long gaming sessions, yet slim enough to fit into a pocket, the Razer Kishi V2 is optimized for both comfort and portability, with each button in just the right place.
- Razer Kishi V2 - gamepad - wired
- Product Type
- Gamepad
- Connectivity Technology
- Wired
- Adjustable width, pass through charging
- Designed For
- iOS
- Product Type
- Gamepad
- Wired
- Interface
- Apple Lightning
- OS Required
- Apple iOS 15.4 or later
- 9.22 cm
- 18.07 cm
- 3.39 cm
- 123 g
- Designed For
- iOS
