Rethink everything you knew about mobile gaming. Razer Kishi V2 is a universal mobile gaming controller that brings a console-class gameplay experience to your smartphone. Play the best AAA games, on your mobile phone, exactly as you'd expect to play them on a game console - zero compromises.
The Razer Kishi V2 is designed to meet the standards of competitive console controllers with cutting edge micro switch buttons, analog triggers, and programmable macros.
Mobile gaming reimagined
Rethink everything you knew about mobile gaming. Razer Kishi V2 is a universal mobile gaming controller that brings a console-class gameplay experience to your smartphone. Play the best AAA games, on your mobile phone, exactly as you'd expect to play them on a game console - zero compromises. -
Console-quality mobile gaming controls
The Razer Kishi V2 is designed to meet the standards of competitive console controllers with cutting edge micro switch buttons, analog triggers, and programmable macros. -
Universal fit with extendable bridge
The Razer Kishi V2 features a stable, extendable bridge that perfectly holds your iPhone, providing a secure fit that won't come loose while you game. -
Ultra-low latency gameplay and passthrough charging
By utilizing Lightning connection, Kishi V2 eliminates input latency, allowing for responsive, seamless control - and features passthrough charging so you can power your phone as you game. -
Comfortable grip in a portable form-factor
Designed for long gaming sessions, yet slim enough to fit into a pocket, the Razer Kishi V2 is optimized for both comfort and portability, with each button in just the right place.
- Razer Kishi V2 - gamepad - wired
- Product Type
- Gamepad
- Connectivity Technology
- Wired
- Designed For
- Android
- Product Type
- Gamepad
- Wired
- Interface
- USB-C
- 9.22 cm
- 18.07 cm
- 3.39 cm
- 123 g
- Designed For
- Android
