Razer Kishi V2 for Android
Quicklinx: HF5GWS00 Mfr#: RZ06-04180100-R3M1
Type: Mobile Gaming Controller
Wired / Wireless: Wired
Compatibility: Android
More than 50 In Stock
£57.50 ex VAT
£69.00 inc VAT
Rethink everything you knew about mobile gaming. Razer Kishi V2 is a universal mobile gaming controller that brings a console-class gameplay experience to your smartphone. Play the best AAA games, on your mobile phone, exactly as you'd expect to play them on a game console - zero compromises.
The Razer Kishi V2 is designed to meet the standards of competitive console controllers with cutting edge micro switch buttons, analog triggers, and programmable macros.
  • Mobile gaming reimagined
  • Console-quality mobile gaming controls
  • Universal fit with extendable bridge
    The Razer Kishi V2 features a stable, extendable bridge that perfectly holds your iPhone, providing a secure fit that won't come loose while you game.
  • Ultra-low latency gameplay and passthrough charging
    By utilizing Lightning connection, Kishi V2 eliminates input latency, allowing for responsive, seamless control - and features passthrough charging so you can power your phone as you game.
  • Comfortable grip in a portable form-factor
    Designed for long gaming sessions, yet slim enough to fit into a pocket, the Razer Kishi V2 is optimized for both comfort and portability, with each button in just the right place.
Razer Kishi V2 - gamepad - wired
Gamepad
Wired
Android
Gamepad
Wired
USB-C
9.22 cm
18.07 cm
3.39 cm
123 g
Android
Brand: Razer
