Bring your A-game anytime, anywhere. Introducing a universal gaming controller that fits most Android devices, designed to bring console-level control to your mobile gaming. With this controller by your side, wherever you go, victory will follow.
- Clickable analog thumbsticks for greater input and tactile feedback
- Fits most Android devices for seamless compatibility
- Latency-free game play for smooth control
- Type C charging port to charge your device while in use
- Ergonomic design for a comfortable handheld grip
Clickable analog thumbsticks for greater accuracy and tactile feedback
Refine your aim and execution with a familiar console controller experience, supported by an array of face and bumper buttons, as well as a D-pad for extra inputs.
The controller’s flexible design allows it to be stretched and clamped on a variety of phones, providing a secure hold that’ll never come loose.
Unlike wireless Bluetooth controllers which produce lag, this controller has zero latency because it connects directly to your device’s charging port—which means instant button response.
If your phone is running low while you’re gaming with the controller still attached, simply hook up a charging cable to the controller itself to get the device charging.
Designed for long gaming sessions, the controller feels great to hold and has optimized button placements to make sure each button press feels natural and intuitive.
Cloud gaming compatible for next-gen gaming
With the reality of playing AAA releases on any screen, having the controller attached to your device provides a form factor convenient and portable enough to truly game anywhere.
Refine your aim and execution with a familiar console controller experience that provides tactile feedback, supported by an array of face and bumper buttons, as well as a D-pad for extra inputs. -
Universal fit
The universal mobile controller's flexible design allows it to be stretched and clamped on most phones, providing a secure hold that'll never come loose while you game. -
Ultra-low-latency gameplay
Because it connects directly to your device's charging port, this mobile controller is able to provide instant button response for smooth, seamless control. -
Ergonomic design
Designed for long gaming sessions, the mobile controller's comfortable handheld grip has optimized button placements to make sure each button press feels natural and intuitive.
- Razer Kishi - gamepad - wired
- Product Type
- Gamepad
- Connectivity Technology
- Wired
- Controls
- A button, B button, D-pad, analogue stick, Home button, X button, Y button
- Designed For
- Android
- 2 Years
- Product Type
- Gamepad
- Wired
- Controls
- Interface
- USB-C
- Designed For
- Android
- 2 Years
