Razer Kaira X for Xbox -Red
Quicklinx: HL7WWS00 Mfr#: RZ04-03970500-R3M1
Recommended Use: Headset
Connectivity: Wired
Earcover : [N/A]
£33.33 ex VAT
£39.99 inc VAT
Conquer on console and beyond with the Razer Kaira X - a wired Xbox Series X headset designed for maximum audio performance and cross-platform compatibility. Armed with advanced drivers and a crystal clear mic, enjoy competition-ready audio no matter where you game.
  • Razer TriForce 50mm drivers
    The Razer Kaira X features advanced drivers that can tune highs, mids, and lows separately - producing brighter, clearer sound with richer trebles and more powerful bass.
  • Fuller sound
    Because the drivers are able to focus on bass, midrange and treble separately, they aren't restricted to a single range unlike traditional designs. This means the sound qualities of each frequency band is enhanced and doesn't muddy.
  • Razer HyperClear cardioid mic
    The bendable mic has improved housing and pickup for amazing voice capture that suppresses noise from the back and sides - supported by mic monitoring and game/chat balance to ensure optimal levels.
  • FlowKnit memory foam ear cushions
    Its breathable weave minimizes sweat and heat build-up, while the ultra-soft foam's improved density greatly reduces the headset's clamping force for snug support during gaming marathons.
  • Works with Windows Sonic
    Make the most of the headset's powerful drivers by pairing it with lifelike surround sound that places audio with pinpoint accuracy - heightening your in-game awareness and immersion.
  • On-headset controls
    Tweak and toggle settings easily with a microphone mute button and volume slider located underneath its left earcup.
  • Cross-platform compatibility
    Aside from its primary use on Xbox, the headset's 3.5mm jack allows it to work with other popular platforms so you can enjoy amazing gaming audio across different setups.
Razer Kaira X for Xbox - headset
Headset - wired - 3.5 mm jack
Recommended Use
Game console, portable electronics, computer
Style
Games
Pulse red
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 96 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Uni-directional (HyperClear flexible cardioid)
Controls
Volume
Xbox Series S, Xbox Series X
Style
Games
15.8 cm
9 cm
19.1 cm
283 g
Pulse red
Earpad Material
Recommended Use
Audio Output
Full size
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
96 dB
Impedance
32 Ohm
Diaphragm
50 mm
Magnet Material
Razer Triforce titanium
Adjustable Headband
Microphone
Boom
Sensitivity
-42 dB
Sensitivity Margin
+/- 3dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Volume
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
Cable Length
1.3 m
Cable Details
Headset cable - 1.3 m
Connectivity: Wired
Earcover : [N/A]
Brand: Razer
