Razer Kaira X for Xbox - White
Quicklinx: GK9DWS00 Mfr#: RZ04-03970300-R3M1
Type: Headset
£33.33 ex VAT
£39.99 inc VAT
POWER. CLARITY. COMFORT.
Conquer on console and beyond with the Razer Kaira X – a wired Xbox Series X|S headset designed for maximum audio performance and cross-platform compatibility. Armed with cutting-edge drivers and a crystal-clear mic, enjoy competition-ready audio no matter where you game.
RAZER™ TRIFORCE 50MM DRIVERS
The Razer Kaira X features cutting-edge drivers that can tune highs, mids, and lows separately - producing brighter, clearer sound with richer trebles and more powerful bass.
FULLER SOUND
Because the drivers are able to focus on bass, midrange and treble separately, they aren’t restricted to a single range unlike traditional designs. This means the sound qualities of each frequency band is enhanced and doesn’t muddy.
RAZER™ HYPERCLEAR CARDIOID MIC
The bendable mic has improved housing and pickup for amazing voice capture that suppresses noise from the back and sides – supported by mic monitoring and game/chat balance to ensure optimal levels.
ON-HEADSET CONTROLS
Tweak and toggle settings easily with a microphone mute button and volume slider located underneath its left earcup.
CROSS-PLATFORM COMPATIBILITY
Aside from its primary use on Xbox*, the headset’s 3.5mm jack allows it to work with other popular platforms so you can enjoy amazing gaming audio across different setups.
  • Power, clarity, comfort
    Conquer on console and beyond with the Razer Kaira X - a wired Xbox Series X headset designed for maximum audio performance and cross-platform compatibility. Armed with cutting-edge drivers and a crystal-clear mic, enjoy competition-ready audio no matter where you game.
  • Razer TriForce 50mm drivers
  • Fuller sound
    Because the drivers are able to focus on bass, midrange and treble separately, they aren't restricted to a single range unlike traditional designs. This means the sound qualities of each frequency band is enhanced and doesn't muddy.
  • Razer HyperClear cardioid mic
    The bendable mic has improved housing and pickup for amazing voice capture that suppresses noise from the back and sides - supported by mic monitoring and game/chat balance to ensure optimal levels.
  • FlowKnit memory foam ear cushions
    Its breathable weave minimizes sweat and heat build-up, while the ultra-soft foam's improved density greatly reduces the headset's clamping force for snug support during gaming marathons.
  • Works with windows sonic
    Make the most of the headset's powerful drivers by pairing it with lifelike surround sound that places audio with pinpoint accuracy - heightening your in-game awareness and immersion.
  • On-headset controls
  • Cross-platform compatibility
    Aside from its primary use on Xbox, the headset's 3.5mm jack allows it to work with other popular platforms so you can enjoy amazing gaming audio across different setups.
Razer Kaira X for Xbox - headset - 3.5 mm jack
Headset - wired - 3.5 mm jack
Compatibility
Windows, Mac
Recommended Use
Game console, computer
White
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 96 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Uni-directional
Controls
Volume
Xbox One, Xbox One S, Xbox One S All-Digital Edition, Xbox One X, Xbox Series S, Xbox Series X
Compatibility
Windows, Mac
283 g
White
Earpad Material
Recommended Use
Audio Output
Full size
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
96 dB
Impedance
32 Ohm
Diaphragm
50 mm
Magnet Material
Razer Triforce titanium
Microphone
Boom
Headset microphone
Uni-directional
Sensitivity
-42 dB
Sensitivity Margin
+/- 3dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Volume
Connector Type
Headset (mini-phone 3.5mm)
Cable
Cable Length
1.3 m
Cable Details
Headset cable - 1.3 m
Type: Headset
Brand: Razer
