Razer Kaira X (Playstation Licensed)
Quicklinx: HF4CWS00 Mfr#: RZ04-03970700-R3G1
Type: Headset
More than 50 In Stock
£33.33 ex VAT
£39.99 inc VAT
Conquer on console and beyond with the Razer Kaira X a wired PlayStation 5 headset designed for maximum audio performance and cross-platform compatibility. Armed with cutting-edge drivers and a crystal-clear mic, enjoy competition-ready audio no matter where you game. The Razer Kaira X features cutting-edge drivers that can tune highs, mids, and lows separately producing brighter, clearer sound with richer trebles and more powerful bass.
Aside from its primary use on PlayStation 5, the headset's 3.5mm jack allows it to work with other popular platforms so you can enjoy amazing gaming audio across different setups.
Its breathable weave minimises sweat and heat build-up, while the ultra-soft foam's improved density greatly reduces the headset's clamping force for snug support during gaming marathons.
The bendable mic has improved housing and pickup for amazing voice capture that suppresses noise from the back and sides supported by mic monitoring and game/chat balance to ensure optimal levels.
Compatible with - PS4, PS5, Xbox One, Xbox Series S and X, PC, Nintendo Switch, Nintendo Swith OLED
Manufacturer's 2 year guarantee
  • Power, clarity, comfort
    Conquer on console and beyond with the Razer Kaira X - a wired PlayStation 5 headset designed for maximum audio performance and cross-platform compatibility. Armed with cutting-edge drivers and a crystal-clear mic, enjoy competition-ready audio no matter where you game.
  • RAZER TriForce 50mm drivers
    The Razer Kaira X features cutting-edge drivers that can tune highs, mids, and lows separately - producing brighter, clearer sound with richer trebles and more powerful bass.
  • FlowKnit memory foam ear cushions
    Its breathable weave minimizes sweat and heat build-up, while the ultra-soft foam's improved density greatly reduces the headset's clamping force for snug support during gaming marathons.
  • RAZER hyper-clear cardioid mic
    The bendable mic has improved housing and pickup for amazing voice capture that suppresses noise from the back and sides - supported by mic monitoring and game/chat balance to ensure optimal levels.
  • Mic mute button and volume slider
    Located underneath its left ear cup, allowing you to toggle the Razer HyperClear cardioid mic easily.
  • Cross-platform compatibility
Razer Kaira X for PlayStation - headset
Headset - wired - 3.5 mm jack
Recommended Use
Game console, portable electronics, computer
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 96 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Uni-directional
Controls
Volume control
Sony PlayStation 5
283 g
Earpad Material
Recommended Use
Audio Output
Full size
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
96 dB
Impedance
32 Ohm
Diaphragm
50 mm
Magnet Material
Razer TriForce
Adjustable Headband
Microphone
Boom
Uni-directional
Sensitivity
-42 dB
Sensitivity Margin
+/- 3dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Volume control
Cable
Cable Length
1.3 m
Sony PlayStation 5
Type: Headset
Brand: Razer
