Kaira Designed for Xbox: Competition-ready console audio
Today Razer also introduced the Kaira Designed for Xbox, a competition-ready console audio headset for Xbox Series X|S, retaining many of the same cutting-edge features available on the Kaira Pro, but aimed at the console purists. The Kaira uses the same Razer TriForce Titanium 50mm Drivers as the Kaira Pro for incredibly immersive audio, and the same Razer HyperClear Cardioid Mic, this time on a non-detachable boom, for clear voice communications. The Kaira uses Xbox Wireless for seamless, low latency connectivity, and features a well-padded headband with soft, breathable ear cushions for long term playing comfort.
COMPETITION-READY CONSOLE AUDIO
Take your competitive advantage to the next level and exert true console dominance with the Razer Kaira for Xbox—an Xbox Series X|S wireless headset that offers superior audio immersion with our most powerful drivers ever, and crystal-clear voice comms with the best headset mic we’ve ever designed.
RAZER™ TRIFORCE TITANIUM 50MM DRIVERS
Our all-new patented design allows our engineers to custom tune each driver as though there are three—allowing for the individual replications of high, mid and low audio frequencies to deliver richer trebles, brighter sound and powerful bass.
The Razer Kaira for Xbox also includes titanium-coated diaphragms, giving added clarity to any vocals you hear so that any comms you receive is always crisp and clear.
RAZER™ HYPERCLEAR CARDIOID MIC
Offering greater speech pickup and noise cancellation, the bendable mic on this Xbox Series X|S wireless headset has an optimized microphone housing which adopts a more open design for minimal obstruction—resulting in improved clarity for a closer recreation of your voice.
FLOWKNIT MEMORY FOAM EAR CUSHIONS
To keep you in peak form during gaming marathons, our new breathable weave minimizes sweat and heat build-up generated by skin contact, while the ultra-soft foam’s improved density greatly reduces the headset’s clamping force.
EQ TOGGLE AND XBOX PAIRING BUTTON
Located on the right earcup, hold down the button to pair your headset easily, and press it twice to cycle through 4 EQ settings—such as FPS Mode that enhances in-game audio like enemy footsteps, and Bass Mode to amplify low frequency sounds.
XBOX WIRELESS
Do away with complicated setups and wireless dongles. This Xbox Series X|S wireless headset provides a direct, low-latency connection to the console, with a great signal range that supports seamless couch gaming.
WINDOWS SONIC
Experience lifelike surround sound that allows the headset to place audio with pinpoint accuracy, heightening your in-game awareness for a competitive edge and truly immersive experience.
ADVANCED APP CONFIGURATION
Supported by the Razer™ Headset Setup for Xbox app, get it sounding exactly the way you want with access to deeper audio customization options such as personal EQ presets, mic monitoring, and more.
Razer triforce titanium 50mm drivers
The patented design allows Razer engineers to custom tune each driver as though there are three - allowing for the individual replications of high, mid and low audio frequencies to deliver richer trebles, brighter sound and powerful bass. The Razer Kaira for Xbox also includes titanium-coated diaphragms, giving added clarity to any vocals you hear so that any comms you receive is always crisp and clear. -
Razer hyperclear cardioid mic
Offering greater speech pickup and noise cancellation, the bendable mic on this Xbox Series X|S wireless headset has an optimized microphone housing which adopts a more open design for minimal obstruction - resulting in improved clarity for a closer recreation of your voice. -
Flowknit memory foam ear cushions
To keep you in peak form during gaming marathons, the breathable weave minimizes sweat and heat build-up generated by skin contact, while the ultra-soft foam's improved density greatly reduces the headset's clamping force. -
EQ toggle and Xbox pairing button
Located on the right earcup, hold down the button to pair your headset easily, and press it twice to cycle through four EQ settings - such as FPS Mode that enhances in-game audio like enemy footsteps, and Bass Mode to amplify low frequency sounds.
- Razer Kaira - headset
- Product Type
- Headset - 2.4/5 GHz - wireless
- Recommended Use
- Game console, computer
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- 2.4/5 GHz radio frequency
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Sound Effects
- Windows Sonic surround sound
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 108 dB
- Impedance
- 32 ohm
- Noise Isolating
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional (HyperClear flexible cardioid)
- Controls
- Game/chat balance, microphone on/mute switch, pair mode, power on/off, volume, status indicator
- 2-year warranty
- Designed For
- Xbox One, Xbox One S, Xbox One X, Xbox Series S, Xbox Series X
- Product Type
- 293 g
- Earpad Material
- FlowKnit memory foam
- Recommended Use
- Xbox Wireless technology
- Max Operating Distance
- 10 m
Audio Output
- Full size
- Dynamic
- Wireless
- Sound Output Mode
- Stereo
- Sound Effects
- Noise Isolating
- 20 - 20000 Hz
- Sensitivity
- 108 dB
- Impedance
- 32 ohm
- Diaphragm
- 50 mm
- Magnet Material
- Razer Triforce titanium
- Adjustable Headband
Microphone
- Boom
- Sensitivity
- -54 dB
- 100 - 10000 Hz
- Signal-To-Noise Ratio
- 60 dB
Remote Control
- Controls
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 15 hour(s)
- Limited warranty - 2 years
- Designed For
