Razer Iskur Black Gaming Chair
Quicklinx: H8R7WS00 Mfr#: RZ38-02770200-R3G1
In Stock
£371.73 ex VAT
£446.07 inc VAT
Perfect Gaming Form. Razer's first gaming chair designed for posture perfect hardcore gaming
  • Ergonomic lumbar support system: Enjoy total lower back support with a built-in, fully adjustable lumbar curve that closely aligns to your spine—ensuring ideal posture for maximum comfort in gaming marathons
  • Multi-layered synthetic leather: Tougher and more durable than standard PU leather, the chair comes wrapped in multi-layered PVC synthetic leather—making it better suited to withstand the wear and tear from hours of daily use
  • High density foam cushions: The denser, durable cushions have a plush feel and offer better contouring, allowing your weight to apply just enough pressure as they mold to support your unique body shape
  • 4D armrests: Adjust the armrests’ height, angle and move them forwards or backwards for a position tailored to the way you sit
  • Engineered to Carry: Able to support a weight of up to 136kg through a combination of its body frame, armrests and wheelbase, the chair also features angled seat edges to maximize its resting surface area
Material
Faux Leather
Item weight
32 Kilograms
Frame material
Polyvinyl Chloride
Maximum weight recommendation
136 Kilograms
Product dimensions: 90D x 70W x 30H centimetres
Manufacturer warranty - 3 years
