Razer Huntsman V3 Pro Mini - UK Layout
Quicklinx: HTJZWS00 Mfr#: RZ03-04990300-R3W1
Hurry, only 1 left in stock!
£132.50 ex VAT
£159.00 inc VAT
FOR THE PRO
Experience response without rival on a scale you’ve never known with the Razer Huntsman V3 Pro Mini—a 60% keyboard featuring our latest analog optical switches. Armed with adjustable actuation and Rapid Trigger Mode for ultra-fast repeated inputs, get the speed you need to rise to the top.
RAPID TRIGGER MODE
Instead of a fixed reset point, keys reset instantly with an upward motion as low as 0.1 mm. This allows for faster repeated keystrokes compared to standard keyboards, which significantly enhances in-game responsiveness.
SNAP TAP MODE
Prioritize the latest input between two selected keys without having to release the previous one. Enjoy more responsive inputs for near-instant directional changes.
ADJUSTABLE ACTUATION
Supporting a full range of actuation from 0.1 to 4.0 mm, customize the switches to be as sensitive as you want and achieve a setting that best suits your playstyle.
40 G ACTUATION FORCE
Enjoy greater response with a lighter actuation force that lets you play and react quicker than ever before. From counter-strafing to aiming to dodging, gain a split-second advantage you need to come out on top in every exchange.
  • Versatile connectivity
    The Razer Huntsman V3 Pro Mini features a wired connection via USB-C, ensuring a stable and fast response during gameplay.
  • Customizable performance
    Users can customize key functions and create macros with ease, enhancing gameplay and workflow efficiency.
  • Dynamic RGB backlighting
    The RGB Chroma backlighting creates vibrant color effects, allowing users to personalize their keyboard's appearance.
  • Durable design
    Constructed from 5052 aluminum alloy and doubleshot PBT, this keyboard is built to withstand rigorous use while maintaining aesthetic appeal.
  • Ergonomic adjustability
    The adjustable height feature allows for a comfortable typing angle, reducing strain during extended use.
Razer Huntsman - keyboard - UK Input Device
Keyboard
Wired
Localization and Layout
Keyboard
Anti-ghosting
Included Software
Razer Synapse 3
Brand: Razer
