FOR THE PRO
Experience response without rival on a scale you’ve never known with the Razer Huntsman V3 Pro Mini—a 60% keyboard featuring our latest analog optical switches. Armed with adjustable actuation and Rapid Trigger Mode for ultra-fast repeated inputs, get the speed you need to rise to the top.
RAPID TRIGGER MODE
Instead of a fixed reset point, keys reset instantly with an upward motion as low as 0.1 mm. This allows for faster repeated keystrokes compared to standard keyboards, which significantly enhances in-game responsiveness.
SNAP TAP MODE
Prioritize the latest input between two selected keys without having to release the previous one. Enjoy more responsive inputs for near-instant directional changes.
ADJUSTABLE ACTUATION
Supporting a full range of actuation from 0.1 to 4.0 mm, customize the switches to be as sensitive as you want and achieve a setting that best suits your playstyle.
40 G ACTUATION FORCE
Enjoy greater response with a lighter actuation force that lets you play and react quicker than ever before. From counter-strafing to aiming to dodging, gain a split-second advantage you need to come out on top in every exchange.
Versatile connectivity
The Razer Huntsman V3 Pro Mini features a wired connection via USB-C, ensuring a stable and fast response during gameplay. -
Customizable performance
Users can customize key functions and create macros with ease, enhancing gameplay and workflow efficiency. -
Dynamic RGB backlighting
The RGB Chroma backlighting creates vibrant color effects, allowing users to personalize their keyboard's appearance. -
Durable design
Constructed from 5052 aluminum alloy and doubleshot PBT, this keyboard is built to withstand rigorous use while maintaining aesthetic appeal. -
Ergonomic adjustability
The adjustable height feature allows for a comfortable typing angle, reducing strain during extended use.
- Razer Huntsman - keyboard - UK Input Device
- Keyboard
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Keyboard
- UK
- Anti-ghosting
- Included Software
- Razer Synapse 3
