Razer Huntsman V3 Pro - UK Layout
Quicklinx: HTK2WS00 Mfr#: RZ03-04970300-R3W1
14 In Stock
£191.17 ex VAT
£229.40 inc VAT
FOR THE PRO
Instantly elevate your play with the champ of esports gaming keyboards—the Razer Huntsman V3 Pro. Supercharged by Rapid Trigger Mode, tap into our latest analog optical switches and execute repeated inputs at unfair speeds, complete with adjustable actuation for truly customized performance.
RAZER™ ANALOG OPTICAL SWITCHES GEN-2
Rapid Trigger and Adjustable Actuation
Max out on precision and response with an esports keyboard featuring our most advanced switches, including Rapid Trigger for ultra-fast repeated inputs, a 0.1 to 4.0 mm adjustable actuation range, and a 100-million keystroke lifespan.
RAPID TRIGGER MODE
Instead of a fixed reset point, keys reset instantly with an upward motion as low as 0.1 mm. This allows for faster repeated keystrokes compared to standard keyboards, which significantly enhances in-game responsiveness.
SNAP TAP MODE
Prioritize the latest input between two selected keys without having to release the previous one. Enjoy more responsive inputs for near-instant directional changes.
ADJUSTABLE ACTUATION
Supporting a full range of actuation from 0.1 to 4.0 mm, customize the switches to be as sensitive as you want and achieve a setting that best suits your playstyle.
40 G ACTUATION FORCE
Enjoy greater response with a lighter actuation force that lets you play and react quicker than ever before. From counter-strafing to aiming to dodging, gain a split-second advantage you need to come out on top in every exchange.
  • Rapid Trigger and adjustable actuation
    Max out on precision and response with an esports keyboard featuring advanced switches, including Rapid Trigger for ultra-fast repeated inputs, a 0.1 to 4.0 mm adjustable actuation range, and a 100-million keystroke lifespan.
  • Rapid Trigger Mode
    Release and repeatedly press keys at a much faster rate than is physically possible on standard keyboards. With the ability to reset keys at the slightest lift of a finger, experience an advantage in speed that is especially useful for movement in first and third-person games.
  • 40 G actuation force
  • Quick onboard adjustments via an LED array indicator
    Make precise, on-the-fly adjustments to actuation height or Rapid Trigger sensitivity with the visual aid of an onboard LED array. Save the settings to the keyboard and get access to greater customization through Razer Synapse.
  • Quick Actuation Adjustment Mode
    Simply hit FN + Tab to begin adjusting the keyboard's actuation point. Next, press any key to test its actuation height and use the digital dial or arrow keys to adjust accordingly. Press Esc to exit the mode and save your settings to the onboard memory.
  • Quick Rapid Trigger Adjustment Mode
    Simply hit FN + Caps Lock to begin adjusting Rapid Trigger settings and press Caps Lk to toggle Rapid Trigger Mode on or off. Next, press any key to test your current Rapid Trigger settings and use the digital dial or arrow keys to adjust accordingly. Press Esc to exit the mode and save your settings to the onboard memory.
  • Multi-function digital dial and dedicated control buttons
    Manage it all right at your fingertips with a dedicated dial for volume and analog switch settings, backed by a trio of buttons for media control and custom macros.
  • Greater resilience and feel
    Made to withstand the wear and tear of intense competitive play, their shine-resistant design and fadeproof legends offer a degree of durability superior to regular keycaps.
  • Brushed aluminum top plate
    Crafted from aircraft-grade aluminum and refined with a smooth brushed metal finish, the esports keyboard's robust casing is built to withstand frequent, intense use and is resistant to warping.
  • Extended gaming support
    Designed to seamlessly snap to the keyboard, the leatherette wrist rest provides firm ergonomic support for your wrists - especially vital for long periods of training and competition.
Razer Huntsman - keyboard Input Device
Keyboard
Wired
Keyboard
Anti-ghosting
Brand: Razer
