Razer Huntsman V2 (Analog Switch) - UK Layout
Quicklinx: GCTTWS00 Mfr#: RZ03-03610300-R3W1
£166.66 ex VAT
£199.99 inc VAT
Experience the best of both worlds with the Razer Ornata V2 - featuring a hybrid switch that merges the benefits of membrane keys and mechanical switches into one singular design.
Fusing the snappy, clicky feedback of a mechanical switch with the familiar, cushioned feel of a conventional keyboard, each keystroke you make on the Razer Ornata V2 is as satisfying as it is precise.
The Razer Ornata V2 has added controls that can be configured to pause, play, skip and tweak everything from brightness to volume - the ultimate convenience as you enjoy your entertainment.
  • Calibrate, control, conquer
    Enter a higher dimension of control with the Razer Huntsman V2 Analog - Razer first analog optical gaming keyboard. Armed with every feature you'd expect from a top-of-the-line design, you'll want for nothing in your pursuit of victory.
  • Razer analog optical switches
    Actuation at the speed of light now comes with more granular control. Fitted with Razer latest and most advanced switches, the Razer Huntsman V2 Analog redefines the limits of what a gaming keyboard can do.
  • Adjustable actuation
    From a light, responsive 1.5mm height for fast-paced gaming, to a full 3.6mm actuation for deeper, more deliberate keystrokes, these switches can be tailored to your play style.
  • Analog input
    Do away with rigid eight-way WASD movement for FPS and racing games with switches capable of smooth 360-degree motion inputs just like analog joysticks and thumb sticks.
  • Dual-step actuation
    With the ability to set two functions within one key press, you'll be able to make more efficient plays especially when it comes to executing advanced combos and skill rotations.
  • Double shot PBT keycaps
    Harder and more durable than ABS plastic, the sturdy, textured keycaps on this analog optical gaming keyboard won't wear down to a shiny finish and have labels which will never fade thanks to their double shot molding process.
  • Powered by Razer Chroma RGB
    With 16.8 million colors and a suite of effects, sync its per-key lighting and under glow with the rest of your battle station, and enjoy greater immersion as it dynamically reacts with over 150 integrated games.
  • Magnetic plush leatherette wrist rest
    Featuring Razer Chroma RGB under glow, the soft, cushioned wrist support magnetically snaps to the keyboard to relieve pressure on your wrists, so you feel less fatigued when gaming over long periods.
  • Multi-function digital dial and four media keys
    Configure them to pause, play, skip and tweak everything from brightness to volume - the ultimate convenience as you enjoy your entertainment.
  • USB 3.0 pass-through
    Instead of reaching over to your rig to plug in a device, you can connect it conveniently to your PC via a USB port in this analog optical gaming keyboard.
Razer Huntsman V2 Analog - keyboard - UK Input Device
Keyboard
Backlit
RGB Chroma
USB, USB-C
Wired
Localization and Layout
Hot Keys Function
Multimedia
Numeric Keypad
Key Switch Type
Razer Analog Optical Switches
44.6 cm x 14.1 cm x 4.5 cm
1.238 kg
Keyboard
Backlit
RGB Chroma
USB, USB-C
Hot Keys Function
Multimedia
Key Switch Type
Anti-ghosting
Palm Rest
Numeric keypad
44.6 cm
14.1 cm
4.5 cm
1.238 kg
USB 3.0 (pass-through)
Cable Length
2 m
USB-C to USB-A adapter
Key Life Span
100 million clicks
