Razer Huntsman Mini
Razer Huntsman Mini
Quicklinx: HKQCWS00 Mfr#: RZ03-03391600-R3W1
Recommended Use: Gaming
Type: Keyboard
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
10 In Stock
£90.84 ex VAT
£109.00 inc VAT
Enter a new dimension of deadly with the Razer Huntsman Mini - a 60% gaming keyboard with cutting-edge Razer Optical Switches. Highly portable and ideal for streamlined setups, it's time to experience lightning-fast actuation in a compact form factor.
  • Razer clicky optical switches
    The go-to choice for gamers who prefer receiving crisp, tactile feedback that sounds as satisfying as it feels.
  • Improved Razer linear optical switches
    Delivering smooth, instant keystrokes with no tactile bump, this 2nd-gen design sports significant enhancements to the acoustics of the switch with sound dampeners to reduce noise as you bottom out your keys.
  • Doubleshot PBT keycaps with side-printed secondary functions
    Designed for greater durability, the keycaps on this 60% gaming keyboard have a premium, textured quality that'll never degrade to a shiny finish or have their labeling wear off with intense use. For easier reference when executing commands and hotkeys, side-printed secondary functions have also been added.
  • Onboard memory and lighting presets
    Take your settings anywhere as you store and activate up to five keyboard profiles without the need for software, and personalize it further with a preloaded suite of Razer Chroma RGB lighting effects.
Razer Huntsman Mini - keyboard - QWERTY - UK - black Input Device
Keyboard
Backlit
RGB Chroma
USB-C
Wired
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia, programmable
Key Switch Type
Razer Clicky Optical Purple
Keyboard
Backlit
RGB Chroma
USB-C
Hot Keys Function
QWERTY UK
Keyboard Technology
Optical
Key Switch Type
Adjustable Height
Detachable Cable
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Razer
