Razer Goliathus Extended Speed Mouse Mat
Quicklinx: 81TMWS00 Mfr#: RZ02-00211700-R3M1
Engineered to exceed the exacting demands of the world's top professional gamers, the highly-adaptable Razer Goliathus Speed Edition successfully melds the full-scale speed, acceleration and razor-sharp responsiveness of hard mats with the precise control and comfort offered by uncoated soft pads. Boasting an improved iteration of Razer's award-winning woven fiber technology, an extra-large size and an exclusive limited edition design, every inch of the Razer Goliathus Speed Edition's durable surface is a glide-versus-resistance sweet spot, making it suitable for all mouse sensitivity setups and playstyles.
  • Slick cloth weave
    The Razer Goliathus Speed Edition's highly taut weave creates a slick, seamless surface that trumps all other gaming cloth mats on the market in terms of flat-out speed.
  • Optimized for all sensitivity settings and sensors
    The Razer Goliathus Speed Edition is optimized for use with all gaming-grade mice, regardless of sensitivity settings and sensor type.
  • Limited Edition Extra-Spacious Extended design
    At 920 x 294 x 4.3mm, the desktop-sized Razer Goliathus Extended offers a vast amount of space for both your keyboard and the most extensive of mouse swipes to give you a broad expanse of cushioned comfort so your hand movements are smooth and seamless during battle frenzies.
Razer Goliathus Extended Speed Edition - mouse pad
Mouse pad
92 cm x 29.4 cm
Mouse pad
92 cm
29.4 cm
Thickness
0.4 cm
Non-slip feet
