If you're looking to make huge plays, then go big with the Razer Gigantus V2. As a soft gaming mouse pad with a textured micro-weave cloth surface, it's designed to help you up your game with fluid swipes and pixel-precise aim.
Textured micro-weave cloth surface
Optimized across all mouse sensors for pixel-precise accuracy and total tracking responsiveness, the weave's high thread count lets your mouse glide across the mat with ease for quick, fluid swipes.Thick, high-density rubber foam with anti-slip baseThis gaming mouse pad remains uniformly flat even over imperfect surfaces, and stays in place when the gaming gets hectic thanks to its grippy underside. With a sturdy foundation for consistent mouse movements, the mat's thickness also serves to cushion your wrist when you game.
- Razer Gigantus V2 Large - mouse pad
- Product Type
- Mouse pad
- Product Material
- Textured micro-weave cloth
- 45 cm x 40 cm
- 1-year warranty
- Product Type
- Mouse pad
- Product Material
- 45 cm
- 40 cm
- Thickness
- 3 mm
- Anti-slip base
- Limited warranty - 1 year
