Razer Gigantus V2 Large
Quicklinx: HNL4WS00 Mfr#: RZ02-03330300-R3M1
11 In Stock
£12.49 ex VAT
£14.98 inc VAT
If you're looking to make huge plays, then go big with the Razer Gigantus V2. As a soft gaming mouse pad with a textured micro-weave cloth surface, it's designed to help you up your game with fluid swipes and pixel-precise aim.
  • Textured micro-weave cloth surface
    Optimized across all mouse sensors for pixel-precise accuracy and total tracking responsiveness, the weave's high thread count lets your mouse glide across the mat with ease for quick, fluid swipes.Thick, high-density rubber foam with anti-slip baseThis gaming mouse pad remains uniformly flat even over imperfect surfaces, and stays in place when the gaming gets hectic thanks to its grippy underside. With a sturdy foundation for consistent mouse movements, the mat's thickness also serves to cushion your wrist when you game.
Razer Gigantus V2 Large - mouse pad
Mouse pad
Product Material
45 cm x 40 cm
1-year warranty
Mouse pad
Product Material
45 cm
40 cm
Thickness
3 mm
Anti-slip base
Limited warranty - 1 year
Brand: Razer
