Ultra-Thin Textured and Profiled Membranes: The facial interface features special membranes that—on a microscopic level—float on the surface of your face, distributing weight to reduce pressure and maximize comfortable wear time.
Hypoallergenic Materials: Made of soft injection-molded silicone free from latex and PU/TPE additives, the facial interface is designed to reduce skin reactions even when worn over long periods.
Designed Using Technology By ResMed: With a design approach driven by billions of hours of data, ResMed’s deep understanding of materials, geometry, and skin science informs every aspect of the product’s creation.
Light-Blocking Design with Ventilation: The snug fit prevents light from spilling in, while its airflow vents allow for warm, moist air to escape so you can enjoy an immersive VR experience with less lens fog and sweat.
Crevice-Free Surface: Grime build-up on the facial interface can be quickly cleaned without worry of any bacteria, dirt, sweat, or oils being trapped.
Contoured 3D Profile: The facial interface foam and silicone feature varying levels of thickness, providing greater support to reduce pressure points and soft, delicate edges for delicate facial skin.
Enhanced comfort
Designed with a blend of foam, polycarbonate, and silicone, this virtual reality headset face interface offers a comfortable fit for extended gaming sessions. Its hypoallergenic materials ensure a safe and irritation-free experience, making it ideal for all users. -
Optimal airflow
Featuring air cooling technology, this face interface promotes better air circulation, reducing the buildup of heat and moisture. Enjoy longer, more comfortable play times without the discomfort of overheating.
- Razer virtual reality headset face interface
- Product Type
- Virtual reality headset face interface
- Product Material
- Silicone, polycarbonate, foam
- 11.5 cm x 17 cm x 11 cm
- 90 g
- Product Type
- Product Material
- 11.5 cm - 17 cm - 11 cm
- 90 g
- Hypoallergenic, air cooling
