- Razer Enki - chair - high-density polyurethane molded foam, elastomeric polyurethane (EPU), steel frame, aluminium base - quartz
- Product Type
- Chair - armrests - T-shaped - tilt - swivel
- Designed For
- Gaming
- Headrest
- Casters
- Lumbar Support
- Material
- High-density polyurethane molded foam, elastomeric polyurethane (EPU), steel frame, aluminium base
- Quartz
- 67 cm
- 68 cm
- 131 cm
- 24.1 kg
- 3 years
- Product Type
- Chair - armrests - tilt - swivel
- Designed For
- Gaming
- Headrest
- Armrest Qty
- 2
- Casters
- Max Load Weight
- 136 kg
- Max User Height
- 204 cm
- Material
- Quartz
- Class 4 gas lift
Seat
- Foam padded
Backrest
- Angle Adjustment
- Lumbar Support
- Foam padded, 152° adjustable angle
Base
- Design
- 5-pointed star
- Casters
- 5 x 6 cm
- Material
- Steel frame, aluminium base
- Polyurethane (PU) casters
Armrests
- Shape
- T-shaped
- Adjustable Armrests
- 4D adjustable
Headrest
- Adjustable Headrest
- No
- Black
- 67 cm
- 68 cm
- 131 cm
- 24.1 kg
- 3 years
