Razer Enki Black Gaming Chair
Quicklinx: HL7TWS00 Mfr#: RZ38-03720300-R3G1
Type: Gaming Chair
£274.17 ex VAT
£329.00 inc VAT
Whether you're looking to kick back or go hard, the gaming never needs to end with the all-day comfort of the Razer Enki. By achieving a sweet spot of comfort through optimal weight distribution, it's time to sink into a gaming chair that redefines all-day comfort.
Fully sculpted lumbar support
Multi-layered synthetic leather
High density foam cushions
  • Designed for all-day comfort
    Through a combination of its unique 110° extended shoulder arches and 21" ultrawide seat base, the Razer Enki gaming chair ensures optimal weight distribution for long-lasting comfort during gaming marathons.
  • Built-in lumbar arch
    The Razer Enki's lumbar curve gently supports your lower back and encourages you to sit in a neutral position, allowing you to maintain the right posture and your back to feel less fatigued when sitting for long periods.
  • Optimized cushion density
    With a softer seat base for a cushier feel, and a firmer seat backing for solid support, the cushioning in this gaming chair complements one another to give you the best of both worlds for unparalleled comfort.
  • Dual-textured, eco sustainable synthetic leather
    To achieve the right mix of comfort and durability, the Razer Enki's core areas are covered in a plush textured fabric for more refined comfort, while its outer edges are lined with smooth leather to better withstand daily wear and tear.
  • Reactive seat tilt and up to 152° recline
    The gaming chair's mechanism allows for intuitive, weight-adjusted tilting so you can lean back and stay supported without having to fiddle with knobs or buttons, while its 152° adjustable recline offers flexible seat positioning that allows you to lay back as far as you want.
  • Premium memory foam head cushion
    To top off your all-day comfort, the Razer Enki comes with a plush head cushion that can mold to the shape of your head and neck, providing cushy support to those key areas.
Razer Enki - chair - high-density polyurethane molded foam, elastomeric polyurethane (EPU), steel frame, aluminium base - black
Chair - armrests - T-shaped - tilt - swivel
Gaming
Headrest
Casters
Lumbar Support
Material
High-density polyurethane molded foam, elastomeric polyurethane (EPU), steel frame, aluminium base
67 cm
68 cm
131 cm - 141 cm
24.1 kg
3 years
Chair - armrests - tilt - swivel
Gaming
Headrest
Armrest Qty
2
Casters
Max Load Weight
136 kg
Max User Height
204 cm
Material
Class 4 gas lift
Seat
Foam padded
Backrest
Angle Adjustment
Lumbar Support
Foam padded, 152° adjustable angle
Base
Design
5-pointed star
Casters
5 x 6 cm
Material
Steel frame, aluminium base
Polyurethane (PU) casters
Armrests
Shape
T-shaped
Adjustable Armrests
4D adjustable
Headrest
Adjustable Headrest
No
67 cm
68 cm
131 cm - 141 cm
24.1 kg
3 years
Type: Gaming Chair
Brand: Razer
