Razer DeathStalker V2 Pro - UK Layout
Quicklinx: GY9TWS00 Mfr#: RZ03-04360300-R3W1
Marketing description is not available.
  • Ultra-fast, ultra-reliable actuation
    Armed with the same lightning-fast response that's a hallmark of all optical keyboards, perform quicker keystrokes with switches that have a shorter actuation height for reduced key travel.
  • Ultra-low-latency gaming
    Experience ultra-low-latency gaming with the 2.4 GHz connection that's even faster.
  • Versatile and convenient
    Use the wireless keyboard on your PC, tablet, and more, as you seamlessly switch between devices.
  • Non-stop use
    With impressive power efficiency to support its optical switches and bright RGB backlight, the Razer DeathStalker V2 Pro has a long battery life.
  • Long-lasting ergonomics
    The keyboard's slim profile ensures neutral hand positioning for long hours of use with little strain, while its aluminum alloy top plate provides greater durability with a satisfying heft.
  • Convenient control
    Configure them to pause, play, skip and tweak everything from brightness to volume - the ultimate convenience as you enjoy your entertainment.
Razer DeathStalker V2 Pro - keyboard - QWERTY - UK Input Device
Keyboard - ergonomic
Backlit
RGB
2.4 GHz, Bluetooth 5.0
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia, programmable
Protection
Scratch-resistant
Key Switch Type
Linear
Case Material
5052 aluminium alloy
Backlit
RGB
Wireless
Hot Keys Function
QWERTY UK
Key Switch Type
Linear
Protection
Scratch-resistant
Carrying Case
Material
Key Life Span
70 million clicks
Included Software
Razer Synapse, Gaming Mode
