Razer DeathAdder V3 Pro - White
Quicklinx: GYB3WS00 Mfr#: RZ01-04630200-R3G1
Type: Mouse
£100.00 ex VAT
£120.00 inc VAT
The Razer DeathAdder is the world's first 3G infrared sensor gaming mouse. This ultimate gaming mouse with ergonomic right-handed design provides maximum comfort during intensive gameplay, and will send enemies scurrying for cover.
  • 63g / 64g Ultra-lightweight Design No deadweight: Made more than 25% lighter than the Razer DeathAdder V2 Pro, enjoy a level of speed and control favored by the world’s top players with one of the lightest ergonomic esports mice ever created.
  • Refined Ergonomic Form Optimized for unrivalled handling and comfort: Developed in partnership with top esports pros, the iconic shape of the Razer DeathAdder has been further improved to continue its legacy of award-winning handling and comfort.
  • Razer Focus Pro 30K Optical Sensor Best-in-class precision: Razer’s brand-new sensor provides flawless tracking performance on a wider variety of surfaces including glass—supported by intelligent functions for enhanced aim and control
  • Razer Optical Mouse Switches Gen-3 No double-clicking issues. No debounce delay: From an improved 90-million click lifecycle with zero double-clicking issues, to a blistering 0.2ms actuation with no debounce delay, the mouse has the reliability and speed built for esport
  • Razer HyperSpeed Wireless 25% faster than other wireless: With a connection 25% faster than any other wireless tech available, enjoy high-performance, low-latency competitive play that remains smooth and stable even in noisy wireless environments.
  • Up To 90 Hours of Battery Life No gaming downtime: With a smaller, lighter battery that boasts greater power efficiency, this wireless ergonomic esports mouse can run for up to 90 hours of continuous play and is rechargeable via USB Type C.
Manufacturer Warranty - 2 Years
  • Zero excess, full performance
    With its incredible weight optimization, the Razer DeathAdder V3 Pro is a lighter ergonomic esports mice - all while improving upon its user experience.
  • Upgradeable to true 4000 Hz wireless polling rate
    Experience a faster wireless performance ever with the Razer HyperPolling wireless dongle. Unlock a standard of responsiveness with the ultimate upgrade for the advanced mice, to secure the speed you need for top-flight competitive gaming.
  • Unlock ultra-fine adjustments
    Enable asymmetric cut-off to individually set a lift-off and landing distance that's tuned to your playstyle - with 26 granular levels of height adjustment compared to only 3 in the previous version.
  • On-mouse DPI control
    Capable of toggling between 5 DPI stages without the need for software, you'll always be ready to compete anywhere with this highly portable, ultra-lightweight esports mouse.
  • Onboard memory
    The mouse stores and uses its last used Razer synapse profile, including all calibrated settings suchas: DPI, polling rate and lift-off distance.
  • Razer hypershift
    Effectively double your inputs at the touch of a button, as you activate an additional set of custom keybinds and DPI stage on the mouse.
Razer DeathAdder V3 Pro - mouse - Bluetooth, USB - white
Mouse - ergonomic
Wireless - Bluetooth, USB
White
Orientation
Right-handed
6.8 cm x 12.8 cm x 4.4 cm
64 g
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
30000 dpi
Performance
90 million clicks, 70 G maximum acceleration, 750 inches per second
Gaming
5 programmable buttons, Razer Hyperspeed Wireless technology, Razer Speedflex Cable, polytetrafluoroethylene (PTFE) feet, Focus Pro optical sensor, Razer 3rd-gen optical mouse switch, on-board memory profile
Mouse
Ergonomic Design
Orientation
Right-handed
Gaming
6.8 cm
12.8 cm
4.4 cm
64 g
White
Input Device
Wireless
Bluetooth, USB
Optical
Buttons Qty
5
Movement Resolution
30000 dpi
Performance
USB dongle, grip tape, USB cable (type-C to type-A) Speedflex, USB dongle adapter
Run Time (Up To)
90 hour(s)
Type: Mouse
Brand: Razer
