Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
Razer DeathAdder V3 Pro - Black
Quicklinx: HKWGWS00 Mfr#: RZ01-04630100-R3G1
Recommended Use: Gaming, Leisure, Office
Type: Mouse, Wireless, Wireless USB Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: Android, Apple iOS, Game console, Mac + 1 more
£100.00 ex VAT
£120.00 inc VAT
Victory takes on a shape with the Razer DeathAdder V3 Pro. Refined and reforged with the aid of top esports pros, its iconic ergonomic form is now more than 25% lighter than its predecessor, backed by a set of cutting-edge upgrades to push the limits of competitive play.
  • Zero excess, full performance
    With its incredible weight optimization, the Razer DeathAdder V3 Pro is a lighter ergonomic esports mice - all while improving upon its user experience.
  • Upgradeable to true 4000 Hz wireless polling rate
    Experience a faster wireless performance ever with the Razer HyperPolling wireless dongle. Unlock a standard of responsiveness with the ultimate upgrade for the advanced mice, to secure the speed you need for top-flight competitive gaming.
  • Unlock ultra-fine adjustments
    Enable asymmetric cut-off to individually set a lift-off and landing distance that's tuned to your playstyle - with 26 granular levels of height adjustment compared to only 3 in the previous version.
  • On-mouse DPI control
    Capable of toggling between 5 DPI stages without the need for software, you'll always be ready to compete anywhere with this highly portable, ultra-lightweight esports mouse.
  • Onboard memory
    The mouse stores and uses its last used Razer synapse profile, including all calibrated settings suchas: DPI, polling rate and lift-off distance.
  • Razer hypershift
    Effectively double your inputs at the touch of a button, as you activate an additional set of custom keybinds and DPI stage on the mouse.
Razer DeathAdder V3 Pro - mouse - Bluetooth, USB - black
Mouse - ergonomic
Wireless - Bluetooth, USB
Orientation
Right-handed
6.8 cm x 12.8 cm x 4.4 cm
63 g
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
30000 dpi
Performance
90 million clicks, 70 G maximum acceleration, 750 inches per second
Gaming
5 programmable buttons, Razer Hyperspeed Wireless technology, Razer Speedflex Cable, polytetrafluoroethylene (PTFE) feet, Focus Pro optical sensor, Razer 3rd-gen optical mouse switch, on-board memory profile
Mouse
Ergonomic Design
Orientation
Right-handed
Gaming
6.8 cm
12.8 cm
4.4 cm
63 g
Input Device
Wireless
Bluetooth, USB
Optical
Buttons Qty
5
Movement Resolution
30000 dpi
Performance
USB dongle, grip tape, USB cable (type-C to type-A) Speedflex, USB dongle adapter
Standby Time
Up to 90 h
Recommended Use: Leisure
Recommended Use: Office
Type: Mouse
Type: Wireless
Type: Wireless USB Mouse
Colour: Black
Compatibility: Apple iOS
Compatibility: Game console
Compatibility: Mac
Compatibility: PC
Brand: Razer
