The Razer DeathAdder is the world's first 3G infrared sensor gaming mouse. This ultimate gaming mouse with ergonomic right-handed design provides maximum comfort during intensive gameplay, and will send enemies scurrying for cover.
High-performance movement detection
The Focus X optical sensor ensures accurate tracking and responsiveness, catering to the needs of both competitive gamers and casual users. -
Reliable wireless connectivity
With Razer Hyperspeed Wireless technology, enjoy a stable connection with minimal interference for uninterrupted gameplay. -
Durable construction
Engineered to withstand intense gaming sessions, the mouse features Razer 3rd-gen optical mouse switch rated for 90 million clicks. -
Smooth and fast glide
Equipped with polytetrafluoroethylene (PTFE) feet, the mouse provides a seamless glide on various surfaces for optimal maneuverability. -
Customizable settings
The on-board memory profile allows for quick access to personalized configurations, giving gamers an advantage in competitive scenarios.
- Razer DeathAdder V3 HyperSpeed - mouse - 2.4 GHz, USB
- Mouse - ergonomic
- Connectivity Technology
- Wireless, wired - 2.4 GHz, USB
- Orientation
- Right-handed
- 6.48 cm x 12.22 cm x 4.13 cm
- 55 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 5
- Movement Resolution
- 26000 dpi
- Performance
- 90 million clicks, 40 G maximum acceleration, 500 inches per second, Focus X 26K sensor
- Gaming
- On-board memory profile, Focus X optical sensor, polytetrafluoroethylene (PTFE) feet, Razer Hyperspeed Wireless technology, Razer 3rd-gen optical mouse switch, scrolling wheel
- 2-year warranty
- Mouse
- Wireless Receiver
- Ergonomic Design
- Orientation
- Right-handed
- Gaming
- 6.48 cm
- 12.22 cm
- 4.13 cm
- 55 g
Input Device
- Wireless, wired
- Interface
- 2.4 GHz, USB
- Optical
- Buttons Qty
- 5
- 26000 dpi
- Performance
- Included Accessories
- USB dongle, USB dongle adapter, USB-C to USB-A cable
- Limited warranty - 2 years
