Razer DeathAdder V3
Razer DeathAdder V3
Quicklinx: HTJYWS00 Mfr#: RZ01-04640100-R3M1
Wired / Wireless: Wired
10 In Stock
£49.17 ex VAT
£59.00 inc VAT
Victory takes on a new shape with the Razer DeathAdder V3. Refined and reforged with the aid of top esports pros, its iconic ergonomic form is now more than 25% lighter than its predecessor, backed by a set of cutting-edge upgrades to push the limits of competitive play.
  • Razer 8K Hz HyperPolling technology
    Experience unrivaled responsiveness with a mouse capable of sending up to 8 times more data in a second, effectively reducing input delay from 1 to 1/8th of a millisecond - the edge every pro needs to stay ahead of the competition.
  • Zero excess, full performance
    With its incredible weight optimization, the Razer DeathAdder V3 is one of the lightest ergonomic esports mice ever created - all while improving upon its user experience.
  • Unlock ultra-fine adjustments
    Enable Asymmetric Cut-off to individually set a lift-off and landing distance that's tuned to your playstyle - with 26 granular levels of height adjustment compared to only 3 in the previous version.
  • Auto-calibrates across different surfaces
    With Smart Tracking, the Razer Focus Pro Optical Sensor is able to maintain a consistent lift-off distance no matter what surface it's used on, allowing for greater control and accuracy.
  • Higher responsiveness & more consistent tracking
    With Motion Sync, the Razer Focus Pro Optical Sensor syncs its signals to the exact intervals your PC extracts information, ensuring you'll get the most current updates of your mouse position for more consistent tracking.
Razer DeathAdder V3 - eSports - mouse - ultra-lightweight - USB
Mouse - ergonomic
Wired - USB
Orientation
Right-handed
6.8 cm x 12.8 cm x 4.4 cm
59 g
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
30000 dpi
Performance
90 million clicks, 70 G maximum acceleration, 750 inches per second
6 programmable buttons, 5 on-board memory profiles, Focus Pro optical sensor, Razer Speedflex Cable, PTFE mouse feet
Mouse
Ergonomic Design
Orientation
Right-handed
6.8 cm
12.8 cm
4.4 cm
59 g
Input Device
Wired
USB
Optical
Buttons Qty
6
Movement Resolution
30000 dpi
Performance
1 x USB - 4 pin USB Type A
Brand: Razer
