The Razer DeathAdder is the world's first 3G infrared sensor gaming mouse. This ultimate gaming mouse with ergonomic right-handed design provides maximum comfort during intensive gameplay, and will send enemies scurrying for cover.
Ergonomics without limits
Over 13 million DeathAdders sold. Over a decade's worth of awards to its name. Iconic ergonomics comes with limitless control, thanks to dual wireless connectivity via ultra-fast Razer HyperSpeed Wireless or Bluetooth, and 7 programmable buttons including 2 quick-access edge buttons. -
Make it your own with Razer customs
Customize your Razer DeathAdder V2 X HyperSpeed to display your passion and personality. Choose from a huge, ever-growing selection of officially licensed designs, or flex your creativity by creating a unique one from the ground up. -
Comfort made iconic - award-winning ergonomic design
Trusted by over 13 million fans worldwide, the DeathAdder's iconic shape has provided wins for countless pros more than any other mouse - including the three-time League of Legends world champ, Faker. -
Low latency, high performance - Razer HyperSpeed wireless
Featuring the same high-speed Razer HyperSpeed Wireless technology used in the top-tier gaming mice, unleash your true potential with an ultra-low latency wireless connection. -
Control with an edge - 7 programmable buttons
Whether you're mapping out the essentials or going all out with advanced macros, have all the control you need at your fingertips with 2 unique quick-access edge buttons and 2 side buttons. -
Razer mechanical mouse switches gen-2
With gold-plated contact points, the switches are more resistant to degrading and have a longer lifespan of up to 60 million clicks. -
Razer 5G advanced optical sensor
Enjoy responsive, pixel-precise aim with an improved sensor that flawlessly tracks your movement with zero spinouts. -
100% PTFE mouse feet
This wireless ergonomic gaming mouse glides smoothly across any surface with mouse feet made from the purest, highest grade of PTFE. -
On-board memory profile
Be ready to compete anywhere with access to your custom keybinds, DPI, and twice the inputs via the Razer HyperShift function.
- Razer DeathAdder V2 X HyperSpeed - mouse - 2.4 GHz, Bluetooth 5.1 LE
- Mouse - ergonomic
- Connectivity Technology
- Wireless - 2.4 GHz, Bluetooth 5.1 LE
- Orientation
- Right-handed
- 6.17 cm x 12.7 cm x 4.27 cm
- 103 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 7
- Movement Resolution
- 14000 dpi
- Performance
- 300 inches per second, 35 G maximum acceleration
- Programmable buttons, Razer 2nd-gen optical mouse switch, 60 million clicks, on-the-fly DPI switching, polytetrafluoroethylene (PTFE) feet, scrolling wheel, Razer 5G optical sensor, on-board memory profile, Razer Synapse 3 enabled, Razer HyperShift
- Battery
- AA / AAA
- OS Required
- Windows 10 or later
- 2-year warranty
- Mouse
- Wireless Receiver
- Ergonomic Design
- Orientation
- Right-handed
- 6.17 cm
- 12.7 cm
- 4.27 cm
- 103 g
Input Device
- Wireless
- Interface
- Optical
- Buttons Qty
- 7
- 14000 dpi
- Performance
- Included Accessories
- AA battery
- AA / AAA
- Run Time (Up To)
- 615 hours
- OS Required
- Limited warranty - 2 years
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HRJ9 051044 Condition: Customer return - item has been opened but is in excellent condition |
£25.95 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
