Razer DeathAdder Re-Spawn Gaming Mouse - infrared - 5 button - USB
Quicklinx: 81NLWS00 Mfr#: RZ01-00151400-R3G1
The Razer DeathAdder is the weapon of choice for gamers seeking a combination of comfort and unbridled gaming precision. Enjoy extended gaming sessions in comfort with its right-handed ergonomic form factor crafted for the world of competitive gaming; and when the difference between victory and defeat is determined between heartbeats, the 3500dpi Razer Precision 3.5G infrared sensor translates your every movement into frags with pinpoint accuracy.
Ergonomic Right-Handed Design
Long after your opponents' skill is eroded by hours of gaming, the Razer DeathAdder's ergonomic right-handed design provides optimum comfort for intense and extended gameplay that keeps you at your sharpest.
Kill what you're aiming at with the new 3500dpi Razer Precision 3.5G infrared sensor that arms you with 4x more precision than a standard 800dpi mouse.
1000Hz Ultrapolling
A response time of 1ms, as compared to that of 125Hz / 8ms found in conventional gaming mice, gives you the competitive edge over your opponents with faster feedback between the Razer DeathAdder and your computer so your movements are executed instantaneously.
Razer DeathAdder - mouse - USB
Mouse
Wired - USB
Orientation
Right-handed
7 cm x 12.8 cm x 4.3 cm
Movement Detection Technology
Infrared
Buttons Qty
5
Movement Resolution
3500 dpi
Performance
1 ms response time
Programmable buttons, scrolling wheel, sensitivity adjustment, Teflon feet, golden USB plug
1 x USB cable - integrated - 2.1 m
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Apple MacOS X 10.4 or later, Microsoft Windows Vista (32/64 bits)
Microsoft Certification
Certified for Windows Vista
Mouse
Orientation
Right-handed
7 cm
12.8 cm
4.3 cm
Input Device
Wired
USB
Infrared
Buttons Qty
5
Movement Resolution
3500 dpi
Performance
1 ms response time
1 x USB - 4 pin USB Type A
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Additional Requirements
Internet connection
System Requirements Details
HD 35 MB
