The Razer DeathAdder Essential retains the classic ergonomic form that's been a hallmark of previous Razer DeathAdder generations. Its sleek and distinct body is designed for comfort, allowing you to maintain high levels of performance throughout long gaming marathons, so you'll never falter in the heat of battle.
Ergonomic form
The Razer DeathAdder Essential retains the classic ergonomic form that's been a hallmark of previous Razer DeathAdder generations. Its sleek and distinct body is designed for comfort, allowing you to maintain high levels of performance throughout long gaming marathons, so you'll never falter in the heat of battle. -
5 Hyperesponse buttons
Independently programmable Hyperesponse buttons give you advanced controls for a competitive edge. -
Up to 10 million clicks
The Razer Mechanical Switches last up to 10 million clicks for longer lifespan and extreme reliability. -
6,400 DPI optical sensor
Allows fast and precise mouse swipes that offer greater control for the most essential gaming needs.
- Razer DeathAdder Essential - mouse - USB
- Mouse - ergonomic
- Connectivity Technology
- Wired - USB
- Orientation
- Right-handed
- 7.3 cm x 12.7 cm x 4.3 cm
- 96 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 5
- Movement Resolution
- 6400 dpi
- Performance
- 220 inches per second, 30 G maximum acceleration
- Programmable buttons, Razer mechanical switches, tactile scroll wheel, green LED backlighting, Razer Synapse 3 (beta) enabled, 1000Hz Ultrapolling
- Cable Length
- 1.8 m
- 2-year warranty
- Mouse
- Ergonomic Design
- Orientation
- Right-handed
- 7.3 cm
- 12.7 cm
- 4.3 cm
- 96 g
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 5
- 6400 dpi
- Performance
- Cable Length
- 1.8 m
- Limited warranty - 2 years
Razer Deathadder Essential (2021)
