Push more pixels in Overwatch, Fortnite, and popular MOBA games with powerful graphics. Combined with an efficient processor with turbo boost speeds, the Razer Blade Stealth has even more performance for video editing, content creation, and higher frame rates when gaming.
The thin bezel Full HD matte display is individually calibrated to ensure acute color accuracy. Featuring 100% sRGB color saturation for exceptional visual clarity whether you're working or gaming.
A thin bezel 4K display with 100% sRGB compatible colors produces high-resolution visuals for cinematic clarity, and a touchscreen that provides greater productivity. The Razer Blade Stealth's 4K display is individually calibrated to ensure color accuracy out of the box.
The keyboard features Razer Chroma single-zone RGB lighting for limitless personalization and style, and a precision glass touchpad that gives you accurate touch controls.
Stay equipped with a full array of connectivity including Thunderbolt 3, USB-C, USB-A, wireless AC, and Windows Hello infrared camera, allowing you to connect faster for total adaptability.
The four stereo speakers and smart amplifier provide greater audio boost and clarity. Dolby Atmos replicates sound in a 3-dimensional space for lifelike immersion that flows all around you.
Work faster, game more
Push more pixels in Overwatch, Fortnite, and popular MOBA games with powerful graphics. Combined with an efficient processor with turbo boost speeds, the Razer Blade Stealth has even more performance for video editing, content creation, and higher frame rates when gaming. -
Complete visual clarity
The thin bezel Full HD matte display is individually calibrated to ensure acute colour accuracy. Featuring 100% sRGB colour saturation for exceptional visual clarity whether you're working or gaming. -
Retina shattering clarity
A thin bezel 4K display with 100% sRGB compatible colours produces high-resolution visuals for cinematic clarity, and a touchscreen that provides greater productivity. The Razer Blade Stealth's 4K display is individually calibrated to ensure colour accuracy out of the box. -
A world of colour at your fingertips
The keyboard features Razer Chroma single-zone RGB lighting for limitless personalization and style, and a precision glass touchpad that gives you accurate touch controls. -
Stay connected
Stay equipped with a full array of connectivity including Thunderbolt 3, USB-C, USB-A, wireless AC, and Windows Hello infrared camera, allowing you to connect faster for total adaptability. -
Immersive audio
- Razer Blade Stealth 13 - 13.3" - Core i7 1165G7 - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Ultrabook
- Operating System
- Windows 10 Home
- Processor
- Intel Core i7 (11th Gen) 1165G7 / 2.8 GHz (4.7 GHz)
- Memory
- 16 GB (provided memory is soldered)
- Storage
- 512 GB SSD
- Display
- 13.3" 1920 x 1080 / Full HD @ 120 Hz - matte
- Graphics
- NVIDIA GeForce GTX 1650 Ti
- Video Memory
- 4 GB GDDR6 SDRAM
- Keyboard
- UK
- Keyboard Backlight
- Yes (RGB)
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.1
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- 30.46 cm x 21 cm x 1.53 cm
- 1.41 kg
- Limited warranty - 1 year
- Product Type
- Ultrabook
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.7 GHz
- Number of Cores
- Quad-Core
- 64-bit Computing
- Intel Turbo Boost Technology 2.0, Intel Platform Trust Technology (PTT)
- RAM
- Speed
- 3733 MHz
Storage
- Main Storage
- 512 GB SSD M.2 PCIe
Display
- 13.3"
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 120 Hz
- Widescreen
- Colour Gamut
- 100% sRGB
- Matte, Factory Calibration, 4.9 mm bezel
Audio & Video
- Graphics Processor
- Video Memory
- 4 GB GDDR6 SDRAM
- Video System Features
- Max-Q design
- Camera
- Yes - HD
- Resolution
- 1 Megapixel
- Video Resolutions
- 720p
- Camera Features
- IR camera, Windows Hello
- Sound
- Four speakers, array microphone
- THX Spatial Audio
- Audio Features
- Smart Amp
Input
- Keyboard, touchpad
- Yes (RGB)
- Keyboard Layout
- UK
- Anti-ghosting, Razer Synapse 3 enabled, Precise Glass Touchpad, single-zone RGB powered by Razer Chroma
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 201
- Capacity
- 53.1 Wh
AC Adapter
- Output
- 100 Watt
Connections & Expansion
- 2 x USB 3.1 Gen 1 , 2 x USB-C (supports Thunderbolt 4) (powered) , Headphone/microphone combo jack
- Black
- Case Material
- Aluminum
- Security
- Included Accessories
- USB-C power adapter
- 1.41 kg
