Just when you thought a gaming laptop couldn't be any more beastly - introducing the Razer Blade 15. Enjoy unrivaled performance packed into a thin chassis.
More cores, more performance
Experience advanced power with an Intel Core processor. Intel's 12th Gen processors bring a revolutionary design with a performance hybrid architecture that combines performance-cores with efficient-cores, offering users the freedom to chat, browse, stream, edit, record, and play. Integrated Killer Wi-Fi 6E AX16900 (Gig+) delivers the next-generation Wi-Fi technology with packet prioritization for a better gaming experience. -
NVIDIA GeForce RTX 30 Series graphics - the ultimate play
NVIDIA GeForce RTX 30 Series Laptop GPUs power the world's fastest laptops for gamers and creators. They're built with Ampere - NVIDIA's 2nd gen RTX architecture - to give you the most realistic ray-traced graphics and cutting-edge AI features like NVIDIA DLSS. Plus, Max-Q Technologies unleash the power of AI to make thin, high-performance laptops that are faster and better than ever. -
Next-gen DDR5 (4800MHz) memory - enhanced response times
Feel the boost with an increase of 1600MHz compared to DDR4, as you enjoy a quicker, smoother experience when loading applications, running games, and performing other everyday PC tasks. -
Optimal thermal performance
The Razer Blade 15 efficiently dissipates heat through the evaporation and condensation of an internal fluid - a design which has enabled the laptop to achieve its thin profile. Upgraded with more fins, fans, and a larger liquid capacity, the system maximizes its nanoparticle thermal blockers and server-grade components to maximize thermal threshold and squeeze every ounce of FPS out of the laptop. -
Powered by Razer Chroma RGB
Personalize the RGB gaming keyboard with over 16.8 million colors and a suite of effects to choose from. Enjoy greater immersion with dynamic lighting effects that occur as you game on over 150 Chroma-integrated titles such as Fortnite, Apex Legends, Warframe, and more. -
Lots and lots of ports
The Razer Blade 15 is equipped with advanced connectivity to accommodate a wide range of devices. It features Wi-Fi 6E (802.11ax), Bluetooth 5.2, Thunderbolt 4, and plenty of ports for external displays and peripherals. -
THX Spatial Audio
An advanced 7.1 surround sound that provides pinpoint positional accuracy when using headphones and speakers, to deliver immersive, lifelike audio for stereo and multi-channel content alike. -
Precise glass touchpad
A large, clickable glass touchpad with Microsoft Precision Touchpad support means smooth and precise control, including a range of gestures for expanded navigation. -
Advanced control system
Take full control with the Razer Synapse 3, from customizing lighting, managing profiles, adjusting fans, and even stepping up graphics performance in Gaming Mode.
- Razer Blade 15 - 15.6" - Intel Core i9 - 12900H - 32 GB RAM - 1 TB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 11 Home
- Processor
- Intel Core i9 (12th Gen) - 12900H / 2.5 GHz, up to 5 GHz / 24 MB Cache
- Memory
- 32 GB DDR5 (2 x 16 GB)
- Storage
- 1 TB SSD - NVMe
- Display
- 15.6" 3840 x 2160 / 4K @ 144 Hz
- Graphics
- NVIDIA GeForce RTX 3080 Ti
- Video Memory
- 16 GB GDDR6 SDRAM
- Gaming
- Keyboard
- UK
- Keyboard Backlight
- Yes (RGB)
- Integrated Webcam
- Networking
- Bluetooth 5.2, 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Gigabit Ethernet
- Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip
- Black
- 35.5 cm x 23.5 cm x 1.699 cm
- 2.01 kg
- Localisation
- Region: United Kingdom
- Limited warranty - 1 year , Limited warranty - battery - 2 years
- Product Type
- Notebook
- Operating System
- Windows 11 Home
Processor / Chipset
- CPU
- Intel Core i9 (12th Gen) 12900H / 2.5 GHz
- Max Turbo Speed
- 5 GHz
- Number of Cores
- 14-core
- Cache
- 24 MB
- Intel Turbo Boost Technology, Intel Platform Trust Technology (PTT)
- RAM
- 32 GB (2 x 16 GB)
- Technology
- DDR5 SDRAM
- Speed
- 4800 MHz
- Rated Speed
- 4800 MHz
Storage
- Main Storage
- 1 TB SSD M.2 PCIe 4.0 x4 - NVM Express (NVMe)
Display
- 15.6" - IPS
- Resolution
- 3840 x 2160 (4K)
- V-Sync Rate at Max Res.
- 144 Hz
- Widescreen
- Colour Gamut
- 100% DCI-P3
- Factory Calibration
Audio & Video
- Graphics Processor
- Video Memory
- 16 GB GDDR6 SDRAM
- Video System Features
- NVIDIA Battery Boost technology, NVIDIA WhisperMode, NVIDIA GPU Boost Technology
- Gaming
- Camera
- Yes - 1080p
- Camera Features
- IR camera, Windows Hello
- Sound
- Eight speakers, 2 multi-array microphones
- THX Spatial Audio
Input
- Keyboard, touchpad
- Yes (RGB)
- Keyboard Layout
- UK
- Chroma lighting system, Per-Key illumination, precision glass touchpad
Communications
- Wireless
- Wireless Controller
- Killer Wi-Fi 6E AX1690
- Network Interface
- Gigabit Ethernet
- IEEE 802.11az
- Technology
- Lithium polymer
- Capacity
- 80 Wh
AC Adapter
- Output
- 230 Watt
Connections & Expansion
- Interfaces Details
- USB-C (supports Thunderbolt 4) , 2 x USB-C 3.2 Gen 2 (Power Delivery 3.0) , 3 x USB 3.2 Gen 2
- Black
- Case Material
- Aluminum
- Surface Finish
- Anodising
- Security
- Illuminated Razer logo, vapor chamber cooling system
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 2.01 kg
Sustainability Information
- TCO Certified
