Razer BlackWidow V4 X (Green Switch) - UK Layout
Quicklinx: HF5KWS00 Mfr#: RZ03-04700300-R3W1
Type: Keyboard
£108.33 ex VAT
£129.99 inc VAT
Run your battestation at optimal capacity with the perfect control hub for your PC setup. Packed with macro and media keys, gain access to advanced commands and shortcuts, as you turn up the immersion with a highly evolved mechanical keyboard that goes all out with Razer Chroma RGB.
  • Customizable control at your fingertips
    From popping your ult to optimizing your skill rotation, expand your arsenal of commands with a set of easy-access macro keys that can be programmed to your playstyle.
  • Convenient control
    Pause, play, skip and tweak everything from brightness to volume - the ultimate convenience as you enjoy your entertainment.
  • Customizable per-key lighting
    With a switch construction that promotes brighter, even lighting, customize each key from over 16.8 million colors and effects.
  • Withstands intense use
    Using a doubleshot molding process to ensure the labeling never wears off, the keycaps also have extra-thick walls which make them extremely tough to withstand intense gaming.
  • Improved keyboard acoustics
    With a layer of special foam under the circuit board and lubricated stabilizers to minimize noise, the Razer BlackWidow V4 X ensures a typing experience that sounds as satisfying as it feels.
Razer BlackWidow V4 X - keyboard - QWERTY - UK Input Device
Keyboard
Backlit
RGB Chroma
USB
Wired
Localization and Layout
QWERTY UK
Hot Keys Qty
6
Hot Keys Function
Programmable, macros buttons, media controls
Numeric Keypad
Gaming
Key Switch Type
Razer Green Gen-3
Keyboard
Backlit
RGB Chroma
USB
Hot Keys Qty
6
Hot Keys Function
QWERTY UK
Keyboard Technology
Mechanical
Key Switch Type
Razer Green Gen-3
Gaming
Numeric keypad
Key Life Span
100 million clicks
Type: Keyboard
Brand: Razer
