Run your battestation at optimal capacity with the perfect control hub for your PC setup. Packed with macro and media keys, gain access to advanced commands and shortcuts, as you turn up the immersion with a highly evolved mechanical keyboard that goes all out with Razer Chroma RGB.
Customizable control at your fingertips
From popping your ult to optimizing your skill rotation, expand your arsenal of commands with a set of easy-access macro keys that can be programmed to your playstyle. -
Convenient control
Pause, play, skip and tweak everything from brightness to volume - the ultimate convenience as you enjoy your entertainment. -
Customizable per-key lighting
With a switch construction that promotes brighter, even lighting, customize each key from over 16.8 million colors and effects. -
Withstands intense use
Using a doubleshot molding process to ensure the labeling never wears off, the keycaps also have extra-thick walls which make them extremely tough to withstand intense gaming. -
Improved keyboard acoustics
With a layer of special foam under the circuit board and lubricated stabilizers to minimize noise, the Razer BlackWidow V4 X ensures a typing experience that sounds as satisfying as it feels.
- Razer BlackWidow V4 X - keyboard - QWERTY - UK Input Device
- Keyboard
- Backlit
- RGB Chroma
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- QWERTY UK
- Hot Keys Qty
- 6
- Hot Keys Function
- Programmable, macros buttons, media controls
- Numeric Keypad
- Gaming
- Key Switch Type
- Razer Green Gen-3
- 2-year warranty
- Keyboard
- Backlit
- RGB Chroma
- Interface
- USB
- Hot Keys Qty
- 6
- Hot Keys Function
- QWERTY UK
- Keyboard Technology
- Mechanical
- Key Switch Type
- Razer Green Gen-3
- Gaming
- Numeric keypad
- Key Life Span
- 100 million clicks
- Limited warranty - 2 years
