Razer BlackWidow V4 Pro (Green Switch) - UK Layout
Quicklinx: HRJ1WS00 Mfr#: RZ03-04680300-R3W1
Recommended Use: Gaming
Type: Keyboard
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
10 In Stock
£165.84 ex VAT
£199.00 inc VAT
Empower your play with a centerpiece that elevates your entire setup. Enter the next phase of battlestation evolution with the ultimate mechanical gaming keyboard. Take full command with a set of features designed for advanced control, and enhance your immersion with full-blown Razer Chroma RGB.
  • Powered by Razer Chroma RGB
    Featuring per-key lighting and a striking underglow that highlights the keyboard from more angles, sync it with your battlestation and enjoy greater immersion for hundreds of integrated games.
  • Maximum commands at your fingertips
    Assume greater control over your battlestation by assigning a custom function to the keyboard's programmable dial. Game with greater command using a set of macro keys for essential keybinds.
  • Razer command dial
    Press the dial to toggle between each mode or hold shift while pressing to return to the previous one. Easily identify which mode the dial is currently on with mode-specific backlight.
  • Quick, precise execution
    Choose between two switches that offer their own distinct feel - the Green Switch for precise actuation with clicky, tactile feedback, or the Yellow Switch for quick actuation that's smooth and silent.
  • Extra gaming comfort and flair
    Designed to provide secure support for long hours of play, the soft, cushioned wrist rest also features Razer Chroma RGB - which perfectly lines up with the keyboard's underglow.
  • Withstands intense use
    Using a doubleshot molding process to ensure the labeling never wears off, the keycaps also have extra-thick walls which make them extremely tough to withstand intense gaming.
  • Convenient control
    Pause, play, skip and tweak everything from brightness to volume - the ultimate convenience as you enjoy your entertainment.
  • USB passthrough
    Connect a mouse or headset conveniently to your PC via a USB port on the keyboard.
  • Enhanced keyboard acoustics
    Satisfying sound profile with pre-lubed stabilizers and 2 layers of internal sound dampening foam.
  • 5 onboard memory profiles
    Save any number of custom profiles to the cloud and store up to 5 of your favorite ones on the keyboard.
Razer BlackWidow V4 Pro - keyboard - 100% full size - with media roller - QWERTY - UK Input Device
Keyboard
Backlit
RGB Chroma
USB
Wired
Built-in Devices
Media roller
Localization and Layout
QWERTY UK
Hot Keys Qty
8
Hot Keys Function
Programmable, macros buttons, media controls
Numeric Keypad
Gaming
Key Switch Type
Razer Green
Keyboard
Backlit
RGB Chroma
USB
Hot Keys Qty
8
Hot Keys Function
QWERTY UK
Keyboard Technology
Mechanical
Key Switch Type
Razer Green
Gaming
Built-in Devices
Media roller
Palm Rest
Detachable Cable
Numeric keypad
USB pass-through
Included Software
Razer Synapse
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Razer
