Run your battestation at optimal capacity with the perfect control hub for your PC setup. Packed with macro and media keys, gain access to advanced commands and shortcuts, as you turn up the immersion with a highly evolved mechanical keyboard that goes all out with Razer Chroma RGB.
Full mechanical keys for superior tactility and faster response
The Razer BlackWidow's mechanical key technology provides a distinctive tactile feedback in form of a light pronounced tap to your fingers giving you an entirely new feel on your keyboard. With its optimised actuation force and a reduced actuation distance, the Razer BlackWidow's keys allow you to actuate your commands faster than on any other standard gaming keyboard. -
On-the-fly macro recording and profiles allow effortless configuration
Record unlimited macros on-the-fly without having to take your eye off the game and immediately change between up to 10 profiles without the hassle of going into complex driver menus. With the simple click of two buttons you initiate and end the recording and you're all set. -
Macro-keys and gaming mode ensure uninterrupted gaming experience
Expand the amount of easy-to-reach commands with the additional 5 macro keys on the side and avoid any distractions by switching on the gaming mode.
- Razer BlackWidow V4 - keyboard full size - with media roller - QWERTY - UK Input Device
- Keyboard
- Backlit
- RGB Chroma
- Interface
- USB-C
- Connectivity Technology
- Wired
- Built-in Devices
- Media roller
- Localization and Layout
- QWERTY UK
- Hot Keys Qty
- 11
- Hot Keys Function
- Macros buttons, media controls, scrolling
- Numeric Keypad
- Gaming
- Key Switch Type
- Razer Green
- 46.6 cm x 15.3 cm x 4.3 cm
- 1.4 kg
- 2-year warranty
- Keyboard
- Backlit
- RGB Chroma
- Interface
- USB-C
- Hot Keys Qty
- 11
- Hot Keys Function
- QWERTY UK
- Keyboard Technology
- Mechanical
- Key Switch Type
- Razer Green
- Gaming
- Built-in Devices
- Media roller
- Palm Rest
- Detachable Cable
- Numeric keypad
- 46.6 cm
- 15.3 cm
- 4.3 cm
- 1.4 kg
- USB-C
- Included Accessories
- Magnetic wrist rest, USB-C cable
- Limited warranty - 2 years
