Face the competition head-on with a lightweight esports headset that thrives under pressure. Introducing the Razer BlackShark V2 X - a triple threat of amazing audio, superior mic clarity, and supreme sound isolation that's approved by pros.
Razer TriForce 50mm drivers
With the ability to tune high, mid, and low audio frequencies individually, the design acts like 3 audio drivers in 1 - generating brighter sound with richer trebles and more powerful bass, with vocals that are clear and crisp. -
Razer HyperClear cardioid mic
Offering greater speech pickup and noise cancellation, the bendable mic on this lightweight esports headset has an optimized microphone housing, which adopts a more open design for minimal obstruction - resulting in improved clarity for a closer recreation of your voice. -
Advanced passive noise cancellation
From cheering crowds to the hum of your rig, shut noise out and enjoy uninterrupted focus with special closed earcups that fully cover your ears, aided by plush cushions that form a closer seal for greater sound isolation. -
Lightweight comfort
You'll barely remember you have it on during gaming marathons. The headset is made even more comfortable thanks to thicker heading padding and improved memory foam ear cushions wrapped in a combination of breathable fabric and plush leatherette. -
7.1 surround sound
Heighten your match awareness and let nothing escape your ears with accurate positional audio that lets you pinpoint intuitively where every sound is coming from. -
Cross-platform compatibility
This lightweight esports headset uses a 3.5mm jack and works across popular platforms, allowing you to seek out competition on PC, Mac, PS4, Xbox One, Nintendo Switch, and mobile devices.
- Razer BlackShark V2 X - headset - 3.5 mm jack
- Product Type
- Headset - 7.1 channel - wired - 3.5 mm jack
- Recommended Use
- Portable electronics, computer, Game console
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- 7.1 channel surround
- Audio Specifications
- Frequency Response 12 - 28000 Hz - Sensitivity 100 dB
- Impedance
- 32 Ohm
- Noise Isolating
- Microphone
- Boom
- Microphone Operation Mode
- Cardioid (uni-directional)
- Controls
- Volume, microphone on/mute
- 2-year warranty
- Product Type
- 240 g
- Earpad Material
- Memory foam
- Recommended Use
Audio Output
- Full size
- Wired
- Sound Output Mode
- Noise Isolating
- 12 - 28000 Hz
- Sensitivity
- 100 dB
- Impedance
- 32 Ohm
- Diaphragm
- 50 mm
- Magnet Material
- Neodymium
Microphone
- Boom
- Sensitivity
- -42 dBV/Pascal
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm)
Cable
- Cable Length
- 1.3 m
- Cable Details
- Headset cable - 1.3 m
- Limited warranty - 2 years
