Razer™ HyperClear Super Wideband Mic
Razer™ TriForce Titanium 50mm Drivers
Razer™ HyperSpeed Wireless Technology
Razer hyperspeed wireless
With a high-speed transmission and extremely low latency, this wireless esports headset has an industry-leading 2.4GHz wireless connection to ensure lossless audio that'll always stay synced to your game. -
Razer TriForce titanium 50mm drivers
The all-new patented design allows engineers to custom tune each driver as though there are three - allowing for the individual replications of high, mid and low audio frequencies to deliver on richer trebles, brighter sound and powerful bass. The Razer BlackShark V2 Pro also includes titanium-coated diaphragms, giving added clarity to any vocals you hear so that any comms you receive is always crisp and clear. -
Razer hyperclear supercardioid mic
The pickup pattern on this detachable 9.9mm mic has more noise rejection from the sides as compared to a cardioid mic, and provides a true recreation of your voice thanks to a sensitive low frequency response and an open microphone housing designed for minimal obstruction. Includes Razer Synapse 3 support for access to advanced mic settings. -
Advanced passive noise cancelation
From cheering crowds to the hum of your rig, this wireless esports headset shuts out noise using special closed earcups that fully cover your ears, aided by plush cushions that form a perfect seal for greater sound isolation. -
Flowknit memory foam ear cushions
The breathable weave minimizes sweat and heat build-up generated by skin contact, while the ultra-soft foam's improved density greatly reduces the headset's clamping force. -
THX spatial audio
Increase your immersion and in-game awareness with next-gen surround sound that provides pinpoint positional accuracy and true-to-life acoustics, as you press your advantage with its latest feature: THX Game Profiles. Apply custom-tuned profiles that enhance existing sound design in your favorite games. Choose between THX Environmental Mode for truly lifelike immersion, or THX Competitive Mode for greater spatial awareness.
- Razer BlackShark V2 PRO - for PlayStation - headset
- Product Type
- Headset - Bluetooth / 2.4 GHz radio frequency - wireless
- Recommended Use
- Game console, portable electronics, computer
- Gaming
- Localisation
- New Zealand
- White
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- Sound Output Mode
- Stereo
- Sound Effects
- Virtual 7.1 channel (Windows sonic), Tempest 3D AudioTech, Spatial Audio
- Audio Specifications
- Frequency Response 12 - 28000 Hz - Sensitivity 100 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional (HyperClear super cardioid)
- Microphone Noise Cancelling
- Controls
- Volume, microphone on/mute, audio presets, Razer SmartSwitch button
- 2-year warranty
- Product Type
- Dimensions & Weight Details
- Inner earcup diameter: 4.2 cm 6.2 cm
- 320 g
- White
- Headband Material
- Steel
- Earpad Material
- Ultra-soft memory foam
- Recommended Use
- Gaming
- Localisation
- New Zealand
Audio Output
- Full size
- Wireless
- Bluetooth Audio Codec
- SBC, AAC
- Sound Output Mode
- Stereo
- Sound Effects
- 12 - 28000 Hz
- Sensitivity
- 100 dB
- Impedance
- 32 Ohm
- Diaphragm
- 50 mm
- Magnet Material
- Razer Triforce titanium
- Razer HyperSpeed Wireless, super wideband (SWB)
Microphone
- Boom
- Form Factor
- Detachable headset microphone
- Sensitivity
- -42 dB
- 100 - 10000 Hz
- Noise Cancelling
- Noise Cancelling Technology
- Razer HyperClear
Remote Control
- Controls
- Cable Details
- Headset cable
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 70 hour(s)
- Run Time Details
- Continuous playback (super wideband): up to 48 hours
- Limited warranty - 2 years
