If competing is your calling, answer it with the Razer BlackShark V2 Pro - the definitive esports gaming headset, unleashed. Powered by Razer HyperSpeed Wireless technology, this triple threat of ultimate mic clarity, audio and sound isolation is the perfect weapon you need to thrive at the highest levels of play.
Razer HyperSpeed Wireless Technology Lossless audio for low-latency wireless gaming
With a high-speed transmission and extremely low latency, our industry-leading 2.4GHz wireless connection ensures lossless audio that’ll always stay synced to your game, so you’ll never miss a beat.
Razer TriForce Titanium 50mm Drivers for high-end audio performance
With titanium-coated diaphragms for added clarity, our new, cutting-edge proprietary design divides the driver into 3 parts for the individual tuning of highs, mids, and lows—producing brighter, clearer audio with richer highs and more powerful lows.
Razer HyperClear Supercardioid Mic for ultra-clear voice quality and advanced mic controls
Able to cut off ambient noise from the back and sides, the removable 9.9mm mic has better voice isolation and produces a truer recreation of your speech, which can be further tuned via Razer Synapse.
Advanced passive noise cancellation for uninterrupted focus
From cheering crowds to the hum of your rig, shut noise out with special closed earcups that full cover your ears, aided by plush cushions that form a perfect seal for greater sound isolation.
Ultra-soft breathable memory foam ear cushions for premium comfort
Wrapped in plush leatherette, the foam’s improved density greatly reduces the headset’s clamping force, while a breathable fabric minimizes sweat and heat build-up generated by skin contact.
Compatible with PC, Mac, PS4, Nintendo Switch
Razer hyperspeed wireless
With a high-speed transmission and extremely low latency, this wireless esports headset has an industry-leading 2.4GHz wireless connection to ensure lossless audio that'll always stay synced to your game. -
Razer TriForce titanium 50mm drivers
The all-new patented design allows engineers to custom tune each driver as though there are three - allowing for the individual replications of high, mid and low audio frequencies to deliver on richer trebles, brighter sound and powerful bass. The Razer BlackShark V2 Pro also includes titanium-coated diaphragms, giving added clarity to any vocals you hear so that any comms you receive is always crisp and clear. -
Razer hyperclear supercardioid mic
The pickup pattern on this detachable 9.9mm mic has more noise rejection from the sides as compared to a cardioid mic, and provides a true recreation of your voice thanks to a sensitive low frequency response and an open microphone housing designed for minimal obstruction. Includes Razer Synapse 3 support for access to advanced mic settings. -
Advanced passive noise cancelation
From cheering crowds to the hum of your rig, this wireless esports headset shuts out noise using special closed earcups that fully cover your ears, aided by plush cushions that form a perfect seal for greater sound isolation. -
Flowknit memory foam ear cushions
The breathable weave minimizes sweat and heat build-up generated by skin contact, while the ultra-soft foam's improved density greatly reduces the headset's clamping force. -
THX spatial audio
Increase your immersion and in-game awareness with next-gen surround sound that provides pinpoint positional accuracy and true-to-life acoustics, as you press your advantage with its latest feature: THX Game Profiles. Apply custom-tuned profiles that enhance existing sound design in your favorite games. Choose between THX Environmental Mode for truly lifelike immersion, or THX Competitive Mode for greater spatial awareness.
- Razer BlackShark V2 PRO - 2023 Edition - headset
- Product Type
- Headset - Bluetooth / 2.4 GHz radio frequency - wireless
- Recommended Use
- Game console, portable electronics, computer
- White
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- Sound Output Mode
- 7.1 channel surround
- Sound Effects
- THX Spatial Audio
- Audio Specifications
- Frequency Response 12 - 28000 Hz - Sensitivity 100 dB/mW
- Impedance
- 32 Ohm
- Noise Isolating
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional (HyperClear super cardioid)
- Controls
- Volume control, microphone on/mute, audio presets, Razer SmartSwitch button
- 2-year warranty
- Product Type
- 320 g
- White
- Earpad Material
- Memory foam
- Recommended Use
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Wireless
- Sound Output Mode
- Sound Effects
- THX Spatial Audio
- Noise Isolating
- 12 - 28000 Hz
- Sensitivity
- 100 dB/mW
- Impedance
- 32 Ohm
- Diaphragm
- 50 mm
- Magnet Material
- Razer Triforce titanium
- Razer HyperSpeed Wireless
Microphone
- Boom
- Form Factor
- Detachable headset microphone
- Sensitivity
- -42 dB
- Sensitivity Margin
- +/- 3dB
- 100 - 10000 Hz
Remote Control
- Controls
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 70 hour(s)
- Run Time Details
- Continuous playback (with 15 min charge): up to 6 hours
- Limited warranty - 2 years
