Get the non-stop comfort you need for all-day competitive play with the Razer BlackShark V2 HyperSpeed - a wireless ultra-lightweight esports headset. Designed for maximum performance and minimal weight, experience a level of clarity and power that never gets in the way of your game.
80 g Ultra-Lightweight Design for all-day gaming without fatigue
Featuring optimized weight reductions and an improved clamping force, the headset provides seamless comfort that keeps you feeling fresh even for the most intense gaming marathons
Razer HyperClear Super Wideband Mic for high-definition, pro-level voice quality
By covering a wider frequency range of sound, this next-gen bendable mic captures an incredible amount of detail in your voice, so that every shotcall to your team sounds clear, rich, and natural
Razer TriForce Titanium 50 mm Drivers for clear and powerful sound
With titanium-coated diaphragms for added clarity, our patented 3-part driver design has been individually tuned for high, mids, and lows to ensure richer trebles, brighter midrange, and bigger bass
Razer HyperSpeed Wireless Technology for maximum responsiveness and reliability
With its industry-leading 2.4 GHz wireless connection, enjoy high-performance, low-latency competitive play with sound that’s perfectly synced to your game
Noise-isolating Earcups with Ultra-soft Memory Foam for uninterrupted focus and long-lasting comfort
The headset’s closed earcups conform to your head shape, creating a perfect seal to shut out distractions-supported by plush padding in a breathable fabric for complete comfort when competing.
70 Hours of Battery Life with Type C Charging for multi-day use on a single charge
A single full charge of the headset provides up to 70 hours of battery life, enabling you to have non-stop competitive gameplay with minimal downtime
Ultra-lightweight design for all-day gaming without fatigue
Featuring optimized weight reductions and an improved clamping force, the headset provides seamless comfort that keeps you feeling fresh even for intense gaming marathons. -
Raze HyperClear super wideband mic for high-definition, pro-level voice quality
By covering a wider frequency range of sound, this next-gen bendable mic captures an incredible amount of detail in your voice, so that every shotcall to your team sounds clear, rich, and natural. -
Razer TriForce titanium 50 mm drivers for clear and powerful sound
With titanium-coated diaphragms for added clarity, the patented 3- part driver design has been individually tuned for high, mids, and lows to ensure richer trebles, brighter midrange, and bigger bass. -
Razer HyperSpeed wireless technology for maximum responsiveness and reliability
With its 2.4 GHz wireless connection, enjoy highperformance, low-latency competitive play with sound that's perfectly synced to your game. -
Noise-isolating earcups with ultra-soft memory Foam for uninterrupted focus and long-lasting comfort
The headset's closed earcups conform to your head shape, creating a perfect seal to shut out distractions - supported by plush padding in a breathable fabric for complete comfort when competing. -
70 hours of battery life with type c charging for multi-day use on a single charge
A single full charge of the headset provides 70 hours of battery life, enabling you to have non-stop competitive gameplay with minimal downtime.
 - Razer BlackShark V2 HyperSpeed - headset - USB-C
- Product Type
 - Headset - Bluetooth / 2.4 GHz radio frequency - wireless, wired - USB-C
- Compatibility
 - Windows
- Recommended Use
 - Computer
- Gaming
- Style
 - Games
- Headphones Form Factor
 - Full size
- Connectivity Technology
 - Wireless, wired
- Wireless Technology
- Headphones Technology
 - Dynamic
- Sound Output Mode
 - Stereo
- Sound Effects
 - THX Spatial Audio
- Audio Specifications
 - Frequency Response 12 - 28000 Hz - Sensitivity 100 dB
- Impedance
 - 32 Ohm
- Noise Isolating
- Microphone
 - Boom
- Microphone Operation Mode
 - Uni-directional
- Microphone Noise Cancelling
- Controls
 - Volume, microphone on/mute, Razer SmartSwitch button
 - 2-year warranty
- Product Type
- Compatibility
 - Windows
- Style
 - Games
- Dimensions & Weight Details
 - Inner earcup diameter: 4.2 cm 6.2 cm
 - 280 g
- Earpad Material
 - Ultra-soft memory foam
- Recommended Use
 - Computer
- Gaming
 - Bendable microphone arm
Audio Output
 - Full size
- Headphones Cup Type
 - Closed
 - Dynamic
 - Wireless, wired
- Bluetooth Audio Codec
 - SBC
- Sound Output Mode
 - Stereo
- Sound Effects
 - THX Spatial Audio
- Noise Isolating
 - 12 - 28000 Hz
- Sensitivity
 - 100 dB
- Impedance
 - 32 Ohm
- Diaphragm
 - 50 mm
- Magnet Material
 - Razer Triforce titanium
 - Razer HyperSpeed Wireless
Microphone
 - Boom
- Form Factor
 - Headset microphone
 - Uni-directional
- Sensitivity
 - -42 dBV/Pascal
- Sensitivity Margin
 - +/- 3dB
 - 100 - 10000 Hz
- Noise Cancelling
- Noise Cancelling Technology
 - Razer HyperClear
Remote Control
- Controls
Cable
- Cable Length
 - 1.8 m
- Cable Details
 - USB-C to USB-A cable - 1.8 m
- Battery
 - Headset battery rechargeable
- Run Time (Up To)
 - 70 hour(s)
- Run Time Details
 - Continuous playback (with 15 min charge): up to 6 hours
 - Limited warranty - 2 years
 - 0 °C
 - 40 °C
