If esports is everything, then give it your all with the Razer BlackShark V2. With an esports headset that's a triple threat of amazing audio, superior mic clarity and supreme sound isolation, your time to turn pro is now.
Razer Triforce titanium 50mm drivers
With the ability to tune high, mid and low audio frequencies individually, Razer's patented design acts like 3 audio drivers in 1 - generating brighter sound with richer trebles and more powerful bass. The Razer BlackShark V2 also includes titanium-coated diaphragms, giving added clarity to any vocals you hear so that any comms you receive is always crisp and clear. -
Razer hyperclear cardioid mic with USB sound card
Offering greater speech pickup and noise cancellation, the removable mic on this esports headset has an optimized microphone housing which adopts a more open design for minimal obstruction - resulting in improved clarity for a closer recreation of your voice. Supported by a USB sound card, you can tweak and enhance your voice output further via Razer Synapse, with access to features such as Mic Boost, Voice Gate, Volume Normalization, Mic Equalizer and Ambient Noise Reduction. -
Advanced passive noise cancellation
From cheering crowds to the hum of your rig, shut noise out and enjoy uninterrupted focus with special closed earcups that fully cover your ears, aided by plush cushions that form a perfect seal for greater sound isolation. -
Flowknit memory foam ear cushions
Razer's breathable weave minimizes sweat and heat build-up generated by skin contact, while the ultra-soft foam's improved density greatly reduces the headset's clamping force. -
THX Spatial Audio
Increase your immersion and in-game awareness with next-gen surround sound that provides pinpoint positional accuracy and true-to-life acoustics, as you press your advantage with its advanced feature: THX Game Profiles. Apply custom-tuned profiles that enhance existing sound design in your favorite games. -
Cross-platform compatibility
This esports headset connects using a 3.5mm jack or through its USB sound card. The 3.5mm jack works across popular platforms, allowing you to seek out competition on PC, Mac, PS4, Xbox One, Nintendo Switch and mobile devices.
- Razer BlackShark V2 - headset - 3.5 mm jack
- Product Type
- Headset - wired - 3.5 mm jack
- Recommended Use
- Portable electronics, computer, Game console
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- THX Spatial Audio
- Audio Specifications
- Frequency Response 12 - 28000 Hz - Sensitivity 100 dB
- Impedance
- 32 ohm
- Noise Isolating
- Microphone
- Boom
- Microphone Operation Mode
- Mono, cardioid (uni-directional)
- Controls
- Volume control, microphone on/mute
- 2-year warranty
- Product Type
- 262 g
- Earpad Material
- FlowKnit memory foam
- Recommended Use
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- THX Spatial Audio
- Noise Isolating
- 12 - 28000 Hz
- Sensitivity
- 100 dB
- Impedance
- 32 ohm
- Diaphragm
- 50 mm
- Magnet Material
- Razer Triforce titanium
Microphone
- Boom
- Form Factor
- Headset microphone
- Sensitivity
- -42 dB
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- Headset (mini-phone 3.5 mm 4-pole)
Cable
- Cable Length
- 1.8 m
- Included Accessories
- USB sound card
- Cable Details
- Headset cable - Razer SpeedFlex - L shaped - 1.8 m
- Limited warranty - 2 years
