Razer Blackshark V2 & USB Mic Enhancer
Quicklinx: GX1MWS00 Mfr#: RZ04-03230100-R3M1
Recommended Use: Portable electronics, Computer, Game console
Connectivity: Wired
Earcover : Binaural
£83.33 ex VAT
£99.99 inc VAT
If esports is everything, then give it your all with the Razer BlackShark V2. With an esports headset that's a triple threat of amazing audio, superior mic clarity and supreme sound isolation, your time to turn pro is now.
  • Razer Triforce titanium 50mm drivers
    With the ability to tune high, mid and low audio frequencies individually, Razer's patented design acts like 3 audio drivers in 1 - generating brighter sound with richer trebles and more powerful bass. The Razer BlackShark V2 also includes titanium-coated diaphragms, giving added clarity to any vocals you hear so that any comms you receive is always crisp and clear.
  • Razer hyperclear cardioid mic with USB sound card
    Offering greater speech pickup and noise cancellation, the removable mic on this esports headset has an optimized microphone housing which adopts a more open design for minimal obstruction - resulting in improved clarity for a closer recreation of your voice. Supported by a USB sound card, you can tweak and enhance your voice output further via Razer Synapse, with access to features such as Mic Boost, Voice Gate, Volume Normalization, Mic Equalizer and Ambient Noise Reduction.
  • Advanced passive noise cancellation
    From cheering crowds to the hum of your rig, shut noise out and enjoy uninterrupted focus with special closed earcups that fully cover your ears, aided by plush cushions that form a perfect seal for greater sound isolation.
  • Flowknit memory foam ear cushions
    Razer's breathable weave minimizes sweat and heat build-up generated by skin contact, while the ultra-soft foam's improved density greatly reduces the headset's clamping force.
  • THX Spatial Audio
    Increase your immersion and in-game awareness with next-gen surround sound that provides pinpoint positional accuracy and true-to-life acoustics, as you press your advantage with its advanced feature: THX Game Profiles. Apply custom-tuned profiles that enhance existing sound design in your favorite games.
  • Cross-platform compatibility
    This esports headset connects using a 3.5mm jack or through its USB sound card. The 3.5mm jack works across popular platforms, allowing you to seek out competition on PC, Mac, PS4, Xbox One, Nintendo Switch and mobile devices.
Razer BlackShark V2 - headset
Headset - wired - 3.5 mm jack
Recommended Use
Game console, portable electronics, computer
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Sound Effects
THX Spatial Audio
Audio Specifications
Frequency Response 12 - 28000 Hz - Sensitivity 100 dB
Impedance
32 Ohm
Noise Isolating
Microphone
Boom
Microphone Operation Mode
Mono, cardioid (uni-directional)
Controls
Volume control, microphone on/mute
262 g
Earpad Material
FlowKnit memory foam
Recommended Use
Audio Output
Full size
Headphones Cup Type
Closed
Wired
Sound Output Mode
Stereo
Sound Effects
THX Spatial Audio
Noise Isolating
Frequency Response
12 - 28000 Hz
Sensitivity
100 dB
Impedance
32 Ohm
Diaphragm
50 mm
Magnet Material
Microphone
Boom
Headset microphone
Sensitivity
-42 dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
Headset (mini-phone 3.5 mm 4-pole)
Cable
Cable Length
1.8 m
USB sound card
Cable Details
Headset cable - Razer SpeedFlex - L shaped - 1.8 m
Recommended Use: Computer
Recommended Use: Game console
Connectivity: Wired
Earcover : Binaural
Brand: Razer
