Razer Black Widow Gaming Keyboard - USB
Quicklinx: 81P6WS00 Mfr#: RZ03-00390500-R3W1
The Razer BlackWidow is the first mechanical gaming keyboard designed to pave the way for a whole new feel and accelerated gameplay. A full mechanical key infrastructure delivers distinctive tactile feedback, superior gaming-grade response and unsurpassed actions per minute with an extended lifespan. Its five additional macro keys with on-the-fly recording and optimized key matrix allow you to stay in complete control of every frenzied battle as you outmaneuver your adversaries and perform back-to-back assaults.
Full Mechanical Keys for Superior Tactility and Faster Response
The Razer BlackWidow's mechanical key technology provides a distinctive tactile feedback in form of a light pronounced tap to your fingers giving you an entirely new feel on your keyboard. With its optimized actuation force of 50g and a reduced actuation distance of 2 mm the Razer BlackWidow's keys allow you to actuate your commands faster than on any other standard gaming keyboard.
On-The-Fly Macro Recording & Profiles allow Effortless Configuration
Record unlimited macros on-the-fly without having to take your eye off the game and immediately change between up to 10 profiles without the hassle of going into complex driver menus. With the simple click of two buttons you initiate and end the recording and you're all set.
Macro-Keys & Gaming Mode ensure uninterrupted gaming experience
Expand the amount of easy-to-reach commands with the additional 5 Macro keys on the side and avoid any distractions by switching on the Gaming Mode.
  • Full mechanical keys for superior tactility and faster response
    The Razer BlackWidow's mechanical key technology provides a distinctive tactile feedback in form of a light pronounced tap to your fingers giving you an entirely new feel on your keyboard. With its optimised actuation force and a reduced actuation distance, the Razer BlackWidow's keys allow you to actuate your commands faster than on any other standard gaming keyboard.
  • On-the-fly macro recording and profiles allow effortless configuration
  • Macro-keys and gaming mode ensure uninterrupted gaming experience
    Expand the amount of easy-to-reach commands with the additional 5 macro keys on the side and avoid any distractions by switching on the gaming mode.
Razer BlackWidow - keyboard Input Device
Keyboard
USB
Wired
Hot Keys Qty
5
Hot Keys Function
Multimedia, macros buttons, macro record button
Profiles support, On-The-Fly macro recording
47.5 cm x 17.1 cm x 3 cm
1.4 kg
1-year warranty
Keyboard
USB
Hot Keys Qty
5
Hot Keys Function
Keyboard Technology
Mechanical
Anti-ghosting
47.5 cm
17.1 cm
3 cm
1.4 kg
1 x USB cable
Microsoft Windows Vista / XP / 7
Limited warranty - 1 year
