Razer Battlefield 4 Taipan Ambidextrous Gaming Mouse
Quicklinx: 9317WS00 Mfr#: RZ01-00780200-R3M1
Battlefield 4™ Collector's Edition
Gain the competitive edge with the same gaming gear used by pro-gamers in the biggest modern combat shooter yet from DICE and EA, only with the Razer Battlefield 4™ Collector's Edition Peripherals and Gear. All these weapons are designed to work perfectly on their own, but when armed together, you become a highly effective soldier honed for victory.
Only in Battlefield™ can you experience this amazing level of all out war.
Only with Razer can you get the competitive edge to obliterate all who oppose you.
Battlefield 4™ Razer Taipan - Ambidextrous Mouse for Gaming
8200 dpi 4G Dual Sensor System
Introducing the all-new 8200 dpi 4G Dual Sensor System - outfitted with a laser and an optical sensor to accurately calibrate the mouse to any surface for exceptional pinpoint tracking. This lets you execute pinpoint accurate shots with ease while moving with instant in-game responsiveness - a sensor that is a perfect match for your lightning fast reflexes.
Improved ambidextrous ergonomics
Designed with extensive feedback from professional gamers, the Razer Taipan's ambidextrous form suits a wide variety of grip styles and hand sizes. Whether you're right-handed or a south-paw; use claw, palm or fingertip-grip, this mouse stays firmly in hand and comfortably so for extended periods of gaming.
Razer Synapse 2.0 enabled
Razer Synapse 2.0 is cutting-edge, intuitive, proprietary software that functions as the Razer Taipan's brain, automatically syncing the gaming mouse to a cloud server to download driver and firmware updates, as well as to save your individual settings without you needing to lift a finger. You'll never have to set up a new mouse at tournaments again when Razer Synapse 2.0 downloads the personal settings from your own Razer Taipan, and ports them to the new mouse, making it an exact replica of your own.
TECH SPECS
4G Dual Sensor System - 8200dpi
Ambidextrous form factor
9 programmable Hyperesponse buttons
1000Hz Ultrapolling
Up to 200 inches per second / 50g acceleration
Approximate size: 124 mm / 4.88" (Length) x 63 mm / 2.48" (Width) x 36 mm / 1.42" (Height)
Approximate Weight: 95g / 0.21 lbs without cable, 132g / 0.29 lbs with cable
PC / Mac with USB port
Windows® 8/ Windows® 7 / Windows Vista® / Windows® XP (32-bit)/ Mac OS X (v10.6-10.8)
Internet connection
100MB of free hard disk space
Razer Synapse 2.0 registration (requiring a valid e-mail), software download, license acceptance, and internet connection needed to activate full features of product and for software updates. After activation, full features are available in optional offline mode.
  • 8200 dpi 4G dual sensor system
    The 8200 dpi 4G dual sensor system - outfitted with a laser and an optical sensor to accurately calibrate the mouse to any surface for exceptional pinpoint tracking. This lets you execute pinpoint accurate shots with ease while moving with instant in-game responsiveness - a sensor that is a perfect match for your lightning fast reflexes.
  • Improved ambidextrous ergonomics
Razer Taipan Battlefield 4 - mouse - USB
Mouse
Wired - USB
Orientation
Right and left-handed
6.3 cm x 12.4 cm x 3.6 cm
132 g
Movement Detection Technology
Laser / optical
Buttons Qty
9
Movement Resolution
8200 dpi
Performance
50 G maximum acceleration, 1000 reports per second, 200 inches per second
Hyperesponse buttons, 4G Dual Sensor System, 1000Hz Ultrapolling, ambidextrous design, 9 programmable buttons
1 x mouse cable - integrated
Apple MacOS X 10.6 - 10.8, Microsoft Windows Vista / XP / 7 / 8
Mouse
Orientation
6.3 cm
12.4 cm
3.6 cm
132 g
Input Device
Wired
USB
Laser / optical
Buttons Qty
9
Movement Resolution
8200 dpi
Performance
1 x USB - 4 pin USB Type A
Software Included
Razer Synapse 2.0
System Requirements Details
Windows XP/Vista/7/8 HD 100 MB , MacOS X 10.6 or later HD 100 MB
