Razer Battlefield 4 Blackshark Expert Gaming Headset
Quicklinx: 9315WS00 Mfr#: RZ04-00720300-R3M1
Battlefield 4™ Collector's Edition
Gain the competitive edge with the same gaming gear used by pro-gamers in the biggest modern combat shooter yet from DICE and EA, only with the Razer Battlefield 4™ Collector's Edition Peripherals and Gear. All these weapons are designed to work perfectly on their own, but when armed together, you become a highly effective soldier honed for victory.
Only in Battlefield™ can you experience this amazing level of all out war.
Only with Razer can you get the competitive edge to obliterate all who oppose you.
Based on military helicopter headset designs
The design of the Razer BlackShark was inspired by aviator headsets worn by attack helicopter pilots. They provide the same level of comfort needed to endure extended mission times and superior sound isolation for absolute command-clarity in the most frenzied situations.
Superior sound isolation for distraction-free gaming and music
With the circumaural design and leatherette sealant of the headset's ear cups, block out all unwanted, ambient noise and only hear the awesome, intense audio of your games and music.
Gaming on the go
The Razer BlackShark's detachable boom microphone makes this a highly versatile headset, at home both at a gaming setup and out on the streets for music playback. Go from immersive gaming audio and smack-talking foes at your desktop to listening to your music out and about in seconds. The combined audio/mic cable works with all portable audio/mobile/computing devices including the iPod, iPhone, iPad, Kindle Fire, Android phones, Razer Blade, Macbook Pro, or today's newer Ultrabooks.
TECH SPECS
Drivers: 40mm neodymium magnets with copper-clad aluminum voice coil
Frequency response: 20Hz - 20KHz
Impedance: 29 O
Sensitivity @ 1KHz: 105dB ± 3 dB
Input power: 50mW
Cable: 1.3m rubber sheathed
Connector: 3.5 mm audio + mic combined jack
Microphone
Frequency response: 50Hz - 16KHz
Signal-to-noise ratio: 50dB
Sensitivity @ 1KHz: -37 dB +/- 4dB
Pick-up pattern: Unidirectional
Hardware Requirements
Devices with separate 3.5mm audio and mic jacks
Devices with combined 3.5mm audio + mic combined jack (works with all portable audio/mobile/computing devices including the iPod, iPhone, iPad, Kindle Fire, Android phones, Razer Blade, Macbook Pro, or today's newer Ultrabooks.)
1m / 3.2ft audio/mic splitter adapter extension cable included
  • Based on military helicopter headset designs
    The design of the Razer BlackShark was inspired by aviator headsets worn by attack helicopter pilots. They provide the same level of comfort needed to endure extender mission times and superior sound isolation for absolute command-clarity in the most frenzied situations.
  • Superior sound isolation for distraction-free gaming and music
    With the circumaural design and leatherette sealant of the ear cups, block out all unwanted, ambient noise and headset's only hear the awesome, intense audio of your games and music.
  • Gaming on the go
    The Razer BlackShark's detachable boom microphone makes this a highly versatile headset, at home both at a gaming setup and out on the streets for music playback. Go from immersive gaming audio and smack-talking foes at your desktop to listening to your music out and about in seconds. The combined audio/mic cable works with all portable audio/mobile/computing devices including the iPod, iPhone, iPad, Macbook Pro and so on.
Razer BlackShark Battlefield 4 - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
Full size binaural
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 105 dB
Impedance
29 Ohm
Noise Isolating
Microphone
Boom
Microphone Operation Mode
Mono
Headset - wired
Recommended Use
Computer
Audio Output
Full size binaural
Wired
Sound Output Mode
Stereo
Noise Isolating
Frequency Response
20 - 20000 Hz
Sensitivity
105 dB
Impedance
29 Ohm
Diaphragm
40 mm
Magnet Material
Neodymium
Microphone
Boom
Mono
Sensitivity
-37 dB
Frequency Response
50 - 16000 Hz
Signal-To-Noise Ratio
50 dB
Audio Input Details
Uni-directional - 50 - 16000 Hz
Connector Type
Headset (mini-phone stereo 3.5 mm)
Cable Details
Headset cable - 1.3 m , Audio splitter - 1 m
