The king returns to raise the game. Enter the Razer Basilisk V3 pro - the advanced gaming mouse. Armed to the teeth with industry-leading technology, unlock your maximum potential with a weapon that pushes the known limits of performance, customization, connectivity, and control.
- Iconic Ergonomic Form with 9 Customizable Controls for unrivalled handling and command. Favored by millions worldwide, the mouse’s signature shape perfectly supports different grips, while its numerous easy-access buttons allow for an endless combination of commands and macros.
- Razer HyperSpeed Wireless (2.4 GHz) and Bluetooth for ultra-low-latency performance or extended battery life. Unleash seamless, low-latency performance that's faster than other wireless tech or switch to Bluetooth for longer hours of gaming. Outfitted with multi-device support for a streamlined setup.
- Up to 285 Hours of Battery Life for long-lasting performance. With up to 535* hours on Bluetooth and 285 hours on Razer HyperSpeed Wireless, last longer in the heat of battle with a mouse designed to play the long game. *May vary depending on usage conditions.
- Razer 5G Advanced 18K Optical Sensor for fine-tuned precision. Tailor the mouse to your playstyle with new, robust set of sensitivity settings. Enjoy responsive, pixel-precise aim with an ultra-reliable sensor that tracks your movement with zero spinouts.
- Razer Mechanical Mouse Switches Gen-2 for improved click durability and consistency. With new gold-plated contact points, the switches are less prone to degrading and have a longer lifespan of up to 60-million clicks, so you can enjoy crisp execution that’s just as consistent.
- Powered by Razer Chroma RGB for a truly immersive experience. Customize from 16.8 million colors and countless lighting effects, and experience greater immersion as the mouse reacts dynamically with hundreds of Chroma-integrated games.
Smooth, free-spin scrolling or tactile cycling
Speed through content with a scroll wheel that free-spins until its stopped, or switch to tactile mode for more precision and satisfying feedback that's ideal for cycling through weapons or skills. -
Customize each zone from over 16.8 million colors and countless lighting effects, and experience greater immersion as they react dynamically with hundreds of Chroma-integrated games. -
Cutting-edge ergonomics and control
Favored by millions worldwide, the mouse's signature shape perfectly supports different grips, while its numerous easy-access buttons allow for an endless combination of commands and macros. -
Best-in-class precision
Razer's industry leading sensor provides flawless tracking performance on a wider variety of surfaces including glass - supported by intelligent functions for enhanced aim and control. -
Unrivaled durability and speed
From an improved 90-million click lifecycle with zero double-clicking issues, to a blistering 0.2 ms actuation with no debounce delay, enjoy reliability and speed that outshines all others.
