Razer Basilisk V3 X HyperSpeed
Quicklinx: HF5LWS00 Mfr#: RZ01-04870100-R3G1
Type: Mouse
10 In Stock
£57.50 ex VAT
£69.00 inc VAT
The king returns to raise the game. Enter the Razer Basilisk V3 pro - the advanced gaming mouse. Armed to the teeth with industry-leading technology, unlock your maximum potential with a weapon that pushes the known limits of performance, customization, connectivity, and control.
  • Iconic Ergonomic Form with 9 Customizable Controls for unrivalled handling and command. Favored by millions worldwide, the mouse’s signature shape perfectly supports different grips, while its numerous easy-access buttons allow for an endless combination of commands and macros.
  • Razer HyperSpeed Wireless (2.4 GHz) and Bluetooth for ultra-low-latency performance or extended battery life. Unleash seamless, low-latency performance that's faster than other wireless tech or switch to Bluetooth for longer hours of gaming. Outfitted with multi-device support for a streamlined setup.
  • Up to 285 Hours of Battery Life for long-lasting performance. With up to 535* hours on Bluetooth and 285 hours on Razer HyperSpeed Wireless, last longer in the heat of battle with a mouse designed to play the long game. *May vary depending on usage conditions.
  • Razer 5G Advanced 18K Optical Sensor for fine-tuned precision. Tailor the mouse to your playstyle with new, robust set of sensitivity settings. Enjoy responsive, pixel-precise aim with an ultra-reliable sensor that tracks your movement with zero spinouts.
  • Razer Mechanical Mouse Switches Gen-2 for improved click durability and consistency. With new gold-plated contact points, the switches are less prone to degrading and have a longer lifespan of up to 60-million clicks, so you can enjoy crisp execution that’s just as consistent.
  • Powered by Razer Chroma RGB for a truly immersive experience. Customize from 16.8 million colors and countless lighting effects, and experience greater immersion as the mouse reacts dynamically with hundreds of Chroma-integrated games.
  • Smooth, free-spin scrolling or tactile cycling
    Speed through content with a scroll wheel that free-spins until its stopped, or switch to tactile mode for more precision and satisfying feedback that's ideal for cycling through weapons or skills.
    Customize each zone from over 16.8 million colors and countless lighting effects, and experience greater immersion as they react dynamically with hundreds of Chroma-integrated games.
  • Cutting-edge ergonomics and control
    Favored by millions worldwide, the mouse's signature shape perfectly supports different grips, while its numerous easy-access buttons allow for an endless combination of commands and macros.
  • Best-in-class precision
    Razer's industry leading sensor provides flawless tracking performance on a wider variety of surfaces including glass - supported by intelligent functions for enhanced aim and control.
  • Unrivaled durability and speed
    From an improved 90-million click lifecycle with zero double-clicking issues, to a blistering 0.2 ms actuation with no debounce delay, enjoy reliability and speed that outshines all others.
Razer Basilisk V3 pro - mouse
Mouse - ergonomic
Wireless
Mouse
Ergonomic Design
Input Device
Wireless
Alkaline
Type: Mouse
Brand: Razer
