Create, control, and champion your playstyle with the Razer Basilisk V3 - the quintessential ergonomic gaming mouse for adjusted performance. With 10+1 programmable buttons, an intelligent scroll wheel, and a heavy dose of Razer Chroma RGB, it's time to light up the competition your way.
Play it your way, like never before
Assign all your macros and secondary functions across 11 easy-access buttons - including its acclaimed multi-function trigger - to execute essential actions like push-to-talk, ping, and more. -
High-profile performance
Seamlessly switch between any of your custom button profiles via a programmable button underneath the mouse for optimized performance with every game and task. -
Perfecting scrolling: Razer HyperScroll Tilt Wheel
The recent scroll wheel innovation offers another level of functionality you can definitely put a finger on. Offering two types of scrolling for more flexibility, it can also toggle automatically between them for truly seamless use thanks to an outstanding intelligent function. -
Virtual acceleration
By turning on this Razer Synapse feature, you'll be able to increase the mouse's scroll speed the faster you scroll, allowing you to navigate through lengthy documents and articles at an even quicker rate. -
RGB that's off the charts: 11 Razer Chroma RGB lighting zones
Bask in the Razer Basilisk V3's glory as you adapt each zone from over 16.8 million colors and countless lighting effects, all while it reacts dynamically with over 150 Chroma-integrated games. -
Razer optical mouse switches Gen-2
With switches that clock in at a blistering 0.2ms actuation speed for up to 70 million clicks, you can expect nothing but crisp, responsive execution with zero misclicks. -
RAZER Focus+ 26K DPI Optical Sensor
Enjoy responsive, pixel-precise aim with an improved sensor that flawlessly tracks your movement with zero spinouts. -
Iconic ergonomic design with thumb rest
Favored by millions worldwide, the mouse's ergonomic form factor perfectly supports your hand while its buttons are optimally positioned for quick and easy access. -
5 on-board memory profiles
Be ready to compete anywhere with access to your custom key-binds, DPI, and twice the inputs via the Razer HyperShift function. -
100% PTFE mouse feet
This gaming mouse glides smoothly across any surface with mouse feet made from the pure, high-grade PTFE.
 - Razer Basilisk V3 - mouse - USB
 - Mouse - ergonomic
- Connectivity Technology
 - Wired - USB
- Orientation
 - Right-handed
 - 6 cm x 13 cm x 4.25 cm
 - 101 g
- Movement Detection Technology
 - Optical
- Buttons Qty
 - 11
- Movement Resolution
 - 26000 dpi
- Performance
 - 70 million clicks, 650 inches per second, 50 G maximum acceleration
 - Scrolling wheel, programmable buttons, tiltable scroll wheel, RGB 16.8 millions multi-colour illumination, Razer Focus+ Optical Sensor
 - 2-year warranty
 - Mouse
- Ergonomic Design
- Orientation
 - Right-handed
 - 6 cm
 - 13 cm
 - 4.25 cm
 - 101 g
Input Device
 - Wired
- Interface
 - USB
 - Optical
- Buttons Qty
 - 11
 - 26000 dpi
- Performance
 - Limited warranty - 2 years
